Kyosho Ultima SC-R Thread >
Old 11-26-2012, 08:19 PM
  #4186
rcjunky10's Avatar
Trader Rating: 227 (100%+)
Thank you for the input, much appreciated!
As for the axles, are they a known weak point?
So the .5mm shimm you referrenced, what is the performance gain?
UOTE=Nexus;11485183]Nice SP for the kid...best pop award!
Id probably keep the ball diff and grab some axles like I was just posting abov
Anyone know if this is a typo? Tebos' CRCRC 2012 setup says 5mm shim under the rear suspension mount??[/QUOTE]
rcjunky10 is offline
Old 11-27-2012, 08:46 AM
  #4187
Trader Rating: 42 (100%+)
I searched and couldn't find the info I was looking for...
Seems I have 3 sets of #65 front springs and no #70s or higher. Can someone definitively tell me the spring rates in lbs? I have a full set of Kyosho rear buggy springs I can use for the front of the SCR, but I can't find out what is equal to a #70, #65, etc SCR spring in lbs.
Nexus is offline
Old 11-27-2012, 09:45 AM
  #4188
Super Moderator
Kraig's Avatar
Trader Rating: 81 (100%+)
No definitive answer here but I was always under the impression that if the part number was 5183-65 it was a #65 spring. So using the attached chart you might be able to figure out where the springs are or you could use a finger test to see if you can tell the difference between the two. The chart might be a good place to start.
Kraig is offline
Old 11-27-2012, 11:53 AM
  #4189
Thanks Kraig...coming to the IL State race by chance?
Ended up finding a #70 front. I need a damn magnifying glass for how Kyosho marks these springs!
Nexus is offline
Old 11-27-2012, 12:28 PM
  #4190
Super Moderator
Kraig's Avatar
I wanted to but I can't find a baby sitter for the kids as the wife will be out of town. I could only find a baby sitter for myself. Seriously though, good luck!
Kraig is offline
Old 11-28-2012, 12:39 PM
  #4191
MIP MATT's Avatar
Default MIP Kyosho Super diff Available NOW!!!!!!
Hey Guys
The MIP Super diff is now available for the RB6/RB5, RT5, and SC 1/10 2wd vehicles. This new Super diff comes with MIP's Machined outdrives, Diff Rings, Diff Balls, Thrust washers, Thrust balls, Diff Gear, Diff Bearings and MIP clear and orange grease. The only thing needed from your original Kyosho diff is the diff screw, T-nut, and Diff spring.
Part # 12158
http://miponline.com/store/mip12158.html
MIP MATT is offline
Old 11-28-2012, 12:55 PM
  #4192
I bought an RT5 on ebay and the previous owner claimed that he had installed a Blitz diff gear in it. I opened it up to confirm and sure enough, it was not a Kyosho part. Looked like an MIP Blitz diff gear. The outdrives and rings were still Kyosho units however. Just FYI.
z1nonly is offline
Old 11-28-2012, 03:14 PM
  #4193
Trader Rating: 24 (100%+)
I don't understand why you would want the MIP diff? It's $40 and you still need a diff screw($6.39) a diff spring($3.69) and t-nut($4.59[you have to buy it with the diff gear]) so you end up with $54.67
Where as you can get the an entire Kyosho diff with the proper greases for $47
goodhews is offline
Old 11-28-2012, 04:58 PM
  #4194
MIP MATT's Avatar
Is there an issue with re-using your old parts from your old Kyosho Ball Diff? Thats our thinking behind it. More quality outdrives that will last longer for less money.
MIP MATT is offline
Old 11-28-2012, 07:21 PM
  #4195
Honestly, i've never had an issue with an outdrive on my my kyosho, obviously i can't speak for everyone.
But, I know when i ran my blitz i broke several mip outdrives.
goodhews is offline
Old 11-29-2012, 07:47 AM
  #4196
mojoman81's Avatar
Trader Rating: 26 (100%+)
After a season of racing with a boosted 10.5 in mine , my diff is fine just need to replace the balls . Outdrives and all look fine.
mojoman81 is offline
Old 11-29-2012, 10:26 AM
  #4197
eper's Avatar
Trader Rating: 14 (100%+)
ive run mod motor for awhile and have blown through quite a few out drives.. i'm defintly gonna try and run a set of these. ran a few of their other products and can honestly say they havent dissapointed. I ran their mip scte full kit for one weekend at a endurance race 400 laps. first time out with the truck as it was a loaner. i made a few tweaks and the truck was a easy 1 second faster a lap and really easy to drive..needless to say we won that event by over 15 laps and it was super easy to drive.
eper is offline
Old 11-29-2012, 04:26 PM
  #4198
MIP MATT's Avatar
We also have our new MIP Keyed CVDs for the Kyosho SC line as well. No more axle breakage and better all around tolerances
http://miponline.com/store/mip12153.html
MIP MATT is offline
Old 11-29-2012, 04:39 PM
  #4199
mojoman81's Avatar
Are you guys going to offer rebuild kits for these items ? To rebuild the kyosho cvds its a little more than im used to paying .
Old 11-29-2012, 06:43 PM
  #4200
Trader Rating: 32 (100%+)
Yes. I just dont know if they are currently available. But if not im sure it will be soon since the production sets were just completed.
Here is info from the MIP website.
#10144 MIP C-CVD™ Rebuild Kit w/ Set Screws
$6.00 691545101446
#11115 MIP Capture Rings (4)
$6.00 691545111155
#12144 MIP 12mm Aluminum Hex Adapters, Kyosho 1/10th (2)
$12.00 691545121444
#12154 MIP CVD™ Keyed Rear Axle, Kyosho Ultima SC Truck (1)
$12.00 691545121543
#12155 MIP C-CVD™ Bone, Kyosho Ultima SC Truck (1)
$15.00 691545121550
#99010 NUT/ M4 x .7 Steel Locknut (6)
$3.50 691545990101
#99016 PIN/ 1/16” x .430” Steel (4)
$3.00 691545990163
#99028 SHSS/ 4-40 x 3/32 Cup Point (4)
$2.50 691545990286
#99029 SHSS/ 4-40 X 1/8 Flat Point (10)
$3.50 691545990293
Pimpin is offline
