Durango DEX210 Thread >
Like Tree80Likes
Old 07-12-2013, 04:19 AM
  #11611
cyclone's Avatar
Does anybody know the length of the std servo horn ? From hole centres ideally, thanks!
cyclone is offline
Old 07-12-2013, 05:34 AM
  #11612
Nego's Avatar
Trader Rating: 107 (100%+)
Need some gearing advice,I'm running a 17.5 on blinki I have it 81/26, how low can I go on the spur with out heating too much up my motor my current temps is about 125-130 or so.
Nego is offline
Old 07-12-2013, 06:53 AM
  #11613
Im running 75/28 with a 10.5 with max punch and timing.
Around 54 degrees celsius after a full pack. 18degrees in the air.
ridgeracer is offline
Old 07-12-2013, 07:22 AM
  #11614
ekt
ekt's Avatar
I run 69/34 in mine.
ekt is offline
Old 07-12-2013, 09:39 AM
  #11615
Captcha's Avatar
Assuming that the durango transmission has a 2.6:1 as does my Kyosho, as well as the AE B4 lineup, then I have two that I run religously.
For a bigger track high speeds I run a 69/34, temp around 140-145 after a 6 minute main.
For a smaller track tourque required I run a 72/33, temp around 135-145 after a 6 minute main.
Both blinky 17.5's. I just find the happy spot for timing on my motor, and let the rest settle itself. I have never cooked a motor or esc, and I have just as much power as the fast guys around me.
Captcha is offline
Old 07-12-2013, 10:38 AM
  #11616
rcjunky1's Avatar
Nego sounds under geared hence his temps, gotta gear up
rcjunky1 is offline
Old 07-12-2013, 11:05 AM
  #11617
Trader Rating: 156 (100%+)
Is the gear ratio 2.6 with both Mid Motor and Rear Motor?
Breeze is offline
Old 07-12-2013, 12:05 PM
  #11618
Trader Rating: 19 (100%+)
Yes, the internal ratio remains constant no matter the motor configuration.
Jonny5 is offline
Old 07-12-2013, 01:27 PM
  #11619
Trader Rating: 2 (75%+)
cyclone,
I just measured one and came up with 13.90 mm.
durangoman is offline
Old 07-12-2013, 01:30 PM
  #11620
Got a really strange question for you guys. I rebuilt my ball diff about 3 weeks ago,broke it in and installed it. I was going through my maintenance schedule today and decided to check the ball diff and see how it was looking. When I tore everything apart the screw that tightens the diff was extremely tight and the diff was a little tight as well. Any idea how it could have tightened up on it's own?
Old 07-12-2013, 02:56 PM
  #11621
madweazl's Avatar
This can happen when the thrust being goes out. Check the nut and bolt that holds the assembly together as well.
madweazl is offline
Old 07-12-2013, 05:38 PM
  #11622
I have a few questions... I am updating my ESC/Motor combo in my DEX tonight as I was at the track and the stock stuff just doesn't work. It doesn't have enough power.. Now my questions..
I am using the Speedpassion Reventon R esc and the Speed passion 8.5 motor so I want to know what gearing you guys would recommend out of the pinions I have.. I am pretty sure stock spur is 87 I have 26/27/28 and 29 pinions. what would be the best. I don't want a ton of speed or power as I am just trying my hand at racing tomorrow and am racing sportsman. I just want to make it around the track.
cripplethreat is offline
Old 07-12-2013, 06:00 PM
  #11623
Trader Rating: 125 (100%+)
I run all SP stuff. I run Reventon Pro w/SP 8.5V3 at 81/24.
If you have any questions. Feel free to pm me or post here.
http://www.rctech.net/forum/electric...on-thread.html
kwiksi is offline
Old 07-12-2013, 06:04 PM
  #11624
75/25, Trackstar 8.5 motor. Hobbywing 120a esc. 5 punch, 4 timing. Motor 52 degrees Celsius after 4400mah
Old 07-12-2013, 07:30 PM
  #11625
Brushless420's Avatar
Trader Rating: 176 (100%+)
Default Kick up
Originally Posted by MikeR
Concerned with what on the alloy front kick up?
Not sure why anyone would be concerned?? I already have the RDRP +11 and will be picking up the Exotek. I think the front design is awesome.
Brushless420 is offline
