Durango DEX210 Thread
#7081
I am going to rebuild my new to me dex210 to run a local indoor CARPET track. It was pointed out to me by a fellow racer the chassis is tweaked at the front. I have a replacement on order. Can I straighten this to keep as a spare? or will it all ways deform back to the tweaked side. Or should I just get the carbon chassis? how prone to tweaking are they? I can only assume it tweaked over time by running countless laps Counter Clockwise.
When rebuilding shocks should I be running limiters in them for carpet, if so what length? What the difference between limiting the shocks with spaces inside or using the droop screws... Or have missed the point completely, Both change the travel of the arms?
#7085
#7086
If you plan to use the front drop screws the Tresrey item does not have the material machined into the part. If you look at the stock part there is a nub where the droop screw hits. Iam going to replace my Tresrey part with a Cream brass part. It has the wing, nub, tid bit.. not sure what to call it.. droop screw rest
#7087
Could you link me to the Cream brass piece you suggest?
SoCal
#7088
Hope this works
Hes got some other nice parts too...
#7089
[QUOTE=Slimsh8t;11021521]Anyone .
#7090
Can anyone help me on the parts that go in the bottom of the front hubs?
The 10+10 and 5+5
The 10+10 and 5+5
#7092
thanks for the picture that helps alot.this buggy is so easy to drive and now i should be faster
#7093
[QUOTE=Slimsh8t;11056090] http://www.oople.com/forums/showthread.php?t=72921. You'll have to PM him from the Oople forum. Great pieces though!
#7094
#7095
See: http://www.oople.com/forums/showthread.php?t=106736
