Durango DEX210 Thread
#7051
That was Ethan5050's car. I just quoted him on it, but I agree about the bullets on the motor wires.
#7052
Is anyone running AE wheels? I saw the front axle tresery offers but what about the rear? I have alot of tires for my AE cars and hate to buy that many more again.
#7053
You can run JC hexes on the back and use ae hex wheels, or use ae pin drive wheels with the original 410 style rear pin drive- just need a shorter pin.
#7054
OK question people and I will get to reading threw this thread but for now I just thought I would throw it out there, I just picked up a used DEX210 from a friend that raced it 3 times on carpet only. I am planning to race it on a tight hard packed track and would like to keep the mid motor configuration, as it is I am sure I will need to redo the shocks as it is stiff for the carpet setup but can you help me as to where I should go and what to do to make this work in the Mid mount config.
Thanks guy's
Sean
Oh I am planning to get the rear weight from Tresery to add the needed weight for traction.
Thanks guy's
Sean
http://www.petitrc.com/setup/durango...RC20120715.pdf
It is probably not going to b perfect because I am running a +8mm chassis, but I did get it to work well with STD chassis too. U should go buy 4 cheap scales from harbor freight and weigh your car rtr and see what percent of weight is over the rear wheels. You need to get it as closes to 65% as u can, this is the key to making it work. If u r at 63% or less it will be really loose.
#7055
This is a good place to start
#7056
Has anyone used the Kyosho BB shocks on the 210?
Not complaining with the 210 Big Bores.
Just curious.
I have the SCR-SP and those Big Bores are the best shocks i've used.
I've been contemplating on trying on a set on the 210.....
Just curious.
#7059
IMO I think you would be better off by spending $12 to replace the ball studs with ones that work with the RPM ball cups unmodified.
#7064
Is there a front hex conversion out there for this car?
#7065
