HPI Vorza Flux 1/8 E-Buggy Thread
#6541
Don't know anyone who makes them in a 3 or 5 pack at all. I actually didn't know HPI made them that way either. I would suggest trying some Robinson Racing. Great steel gears!!!!!!!! Only kind I use. Only way you will have to change your spur gear, if you don't want to, is if the pitch is different between them. You might want to, to prevent the possible over heating..... So be careful on your gearing and on your 1st run I would monitor the temps to see what the side effects of the different gearing is.
#6542
Guys today I took three teeth off the pinion gear when it came loose. I would like to order more then just the 15 tooth. I'm thinking that since I think it has enough acceleration I want a little more top speed. I run a 4 cell lipo battery that is 5,000 mah. So I would like to get the 15, 16, 17, and probably 18 teeth pinion gears. Other then HPI where can I get these gears? Does someone sell them in like a 3 or 5 pack? Also if I need to I will buy the Spur gears in different sizes.
What do you guys think? Thanks for all the help. Will I have trouble with this over heating?
#6543
http://www.ebay.com/itm/Caster-Racin...item35b5c547c1
#6546
I need the lower ones for the medium track I race at. Actually its more of a large track but the way it is figured smaller straight aways and larger jumps I need some acceration also. I only use the 4s batteries but have been thinking of getting more batteries... Do I have to change anything to go to the 6s? What batteries do you recomend? I was at an oval track and basicly was close to top speed all I had to do was let out of it for a second coming into the turn and get back on it and it and it be full throttle around the oval...
#6547
Thanks for that.
to run 6s requires no modifications at all. get some high C rate baetteries, i highly recomend the turnigy NanoTech 45-90C 5000. my vorza rips with those in it
#6548
hey guys does anyone have the 112mm shock tower and 112mm shocks? I think you should go back to the stock setup and sell me upgraded shocks. You don't need all that stuff bashing
If anyone has an extra set of this extended shocks or shock tower let me know! in the market
#6552
What's up with HPI?????????
They now say the new to be released Vorza with the 2.4 transmitter will be another month in coming. Trouble is, they've been saying this for about 6 months!! I don't know what their issues are, but it's damn frustrating for we in the waiting. I wish there was a comparable RTR from which to choose, a little competition would get them off their behinds.
#6553
#6554
Dont worry, the original Vorza will go down in history as a classic. Im glad to be a part of it, and this forum especially. great guys, and very helpfull information, and in that spirit, illd like to share a great source of very reasonably priced parts for us. some of you may know of it alredy, as hes a guy that has hung around on the D8T forum for many years. BrianR34. hes got a place on Ebay and ONLY sells D8, Hara, and D8T parts, cheaper than aywhere else, that ive found. do check him out.
Anyways, i need an answer fom those in the know, since i havent got my D8, and Vorza side by side to check, will the D8 Hara Center driveshafts fit the Vorza?? These ones here> (also from BrianR34) http://www.ebay.com.au/itm/NEW-Hot-B...item27bf78374e
Thanks Peeps
Thanks Peeps
