SC10 Thread
Old 04-06-2012 | 04:58 AM
  #11101
elex300's Avatar
It goes under the rearshock tower between the gear box and the hinge pin holder.
elex300 is offline
Old 04-06-2012 | 05:06 AM
  #11102
Originally Posted by LOSI123
Hey guys, I just went out the front on the road with the rtr tires and slammed the ride height and body, put in gear diff, tightened slipper, stiffened up the front and added a few shock limiters all round, Installed a 9.5T Boosted, added some weight and moved pack to middle.
Simply One Word "Awesomeness!!!!!!!!!!"
I cant wait for my on board camera to come in
Make sure its not all onboard, get some video from outside the truck
Tim3 is offline
Old 04-07-2012 | 09:15 AM
  #11103
CHIZZLE's Avatar
What bodies fit around the Hazard wheels? The stock body on mine works but I just put together an SC10 for my son, picked up a Proline F150 body for a "slash/sc10", but it doesn't fit. Won't fit around the tires.
CHIZZLE is offline
Old 04-07-2012 | 09:18 AM
  #11104
Jokermayhem's Avatar
Jconcepts high flow...
Jokermayhem is offline
Old 04-07-2012 | 09:28 AM
  #11105
+1
Brian L is offline
Old 04-07-2012 | 08:33 PM
  #11106
darryl80's Avatar
Angry
i am having major problems with the ball differential in my sc10 2wd right now. should i invest in a gear differential? when i press the throttle on my radio it moves very slow. i am at a stand still of what can be going on. please help me.
darryl80 is offline
Old 04-07-2012 | 08:43 PM
  #11107
bajabro's Avatar
Is it tightened up
bajabro is offline
Old 04-07-2012 | 08:49 PM
  #11108
darryl80's Avatar
yes i tightened the screw to what the manual says to tighten it to and it still will not move how it should. what else could be going on?
darryl80 is offline
Old 04-07-2012 | 08:50 PM
  #11109
http://www3.towerhobbies.com/cgi-bin...?&I=LXWTN4&P=7 get this. It will easily handle any brushless setup and will reduce diff rebuilds. BTW it's super light so rotational mass is very minimal.
rc10t3b4 is offline
Old 04-07-2012 | 08:53 PM
  #11110
Rebuild it, sounds like you are missing the spring or something
LeftyAEguy is offline
Old 04-07-2012 | 08:54 PM
  #11111
darryl80's Avatar
rc10t3b4 are you sure that link you gave me for that part will fix my problem 100%
darryl80 is offline
Old 04-07-2012 | 08:58 PM
  #11112
Tighten your diff first like others suggested. But if you still running into issues or even destroying your diff this upgrade is a much better option then a gear diff. I used one in my old T4 ft for 4-5years and only did 1 diff rebuild. I was running a 7700 and a tekin 8.5 and never had issues.
rc10t3b4 is offline
Old 04-07-2012 | 09:01 PM
  #11113
So when you hit the throttle, the truck barely moves? What does it sound like? Sure it's not the slipper?
rc10t3b4 is offline
Old 04-07-2012 | 09:02 PM
  #11114
darryl80's Avatar
how many screws does it take to get the rear differential taken off the sc10?
darryl80 is offline
Old 04-07-2012 | 09:11 PM
  #11115
Not that many. Takes 5mins top to get the transmission taken apart.
rc10t3b4 is offline
