SC10 Thread
Old 04-04-2012 | 01:48 PM
  #11071
J_Bone's Avatar
Nice!! The scenery is great and I like the music.
J_Bone is offline
Old 04-04-2012 | 02:06 PM
  #11072
J_Bone's Avatar
Originally Posted by AlanHall
Maybe one of you guys who are really into setups can check this video and help me with something .. seems like no matter how I land I get a good bounce definitely in the rear. Maybe it need to jump on the power sooner? Or something with the setup?
Its red / grey 32.5/32.5 , arms level/bones level. I have 3oz in the back I was thinking about pulling. I start 2nd here.. black nose blue stars.
http://m.youtube.com/#/watch?desktop...yudJl8zo&gl=US
I think I saw you were running in stock class? If so, remove the weight first. Then see how it drives. It might be OK after that. When I ran Mod, I used 2-3oz. But with my stock 13.5 I run only 1/2oz next to my RX to counter weight of motor and ESC.
I run 30wt. with silver springs and the track I run on has bigger jumps. So if weights don't help, try softer spring.
J_Bone is offline
Old 04-04-2012 | 02:12 PM
  #11073
AlanHall's Avatar
Thanks.. I was thinking it was bottoming out and bouncing it back up. You can see how the back bucks when I land. And yeah its 13.5 blinky.
AlanHall is offline
Old 04-04-2012 | 02:52 PM
  #11074
CR0SS's Avatar
The scenery around here does not suck.
CR0SS is offline
Old 04-04-2012 | 05:41 PM
  #11075
Originally Posted by Mizchief
U using bleeder caps? I've used the Al caps without the bleeder and it's hard to get all of the rebound out without getting air inside. Either air or a little rebound could cause extra pressure and cause them to leak.
yes i am using the bleeder caps on my v2's ya think i need to remove the bleeder screw eh?
jstump is offline
Old 04-04-2012 | 05:45 PM
  #11076
JEFFs SC10's Avatar
those grey springs are way too stiff. Go to greens. Try to run the least amt of weight as possible, you'll have to really master trigger control but the less weight you have the better it rotates, jumps, turns, everything.
JEFFs SC10 is offline
Old 04-04-2012 | 07:36 PM
  #11077
AlanHall's Avatar
Aren't green just one step softer than grey? I tried green/blue and really like the truck everywhere accept if I bobble .. I crashed a ton more lol
AlanHall is offline
Old 04-04-2012 | 07:42 PM
  #11078
AlanHall's Avatar
I say lose the aluminum caps.
AlanHall is offline
Old 04-04-2012 | 07:44 PM
  #11079
AlanHall's Avatar
Did yall see me throw it away the like 3 times I caught the leader lol
AlanHall is offline
Old 04-04-2012 | 07:52 PM
  #11080
J_Bone's Avatar
NO, Silver.
ASSOCIATED REAR B4/T4/SC10
PART # COLOR RATE
6481 BLACK 1.74
6480 GREEN 1.9
6478 SILVER 2.1
6482 GREY 2.33
7434 BLUE 2.55
7435 GOLD 2.75
7436 RED 2.95
J_Bone is offline
Old 04-04-2012 | 08:09 PM
  #11081
AlanHall's Avatar
Shoot your right. Ill have to try it next time out. I did try gold/silver but that was with #2 pistons all around.
AlanHall is offline
Old 04-05-2012 | 02:40 AM
  #11082
savannahmick's Avatar
Default Upgrading my SC10!
I have put some good money into my SC10 by buying all the FT options and a Speed Passion 17.5 esc/motor. Anyway my question is about the RPM arms I have been using them for awhile but they seem to soft/flexible and should I just go back to the stiffer standard arms? Also what gearing are you guys using with a 17.5 setup? One last question my SP 17.5 has vent holes in the motor can and should I cover the vent holes(piece of nitro air filter) since my track is dusty? Anybody else using the M2C tapered hole pistons? Thanks for any info/help!
savannahmick is offline
Old 04-05-2012 | 03:14 AM
  #11083
bzb
never use rpm arms, even tbirdjunkie would say that
any of you drive with black rear, gold front? wich oil to use?
bzb is offline
Old 04-05-2012 | 04:11 AM
  #11084
nadan805's Avatar
I'm running my 17.5 at 23/84, everyone will tell you something different.. I would also never block any vent holes on the motor can. Even when I was a basher, I never had problems with stuff getting in the motor.
nadan805 is offline
Old 04-05-2012 | 07:02 AM
  #11085
J_Bone's Avatar
RPM arms are good in that they are a bit more flexible. You will not miss any races from breaking like you would with the stock arms. But you should check you hinge pins to see if they are bent. The stress will divert from the arms and back onto the hinge pins.
I use RPM arms for the durability. I run on a clay outdoor track with good size jumps and it can get a bit bumpy at times. So they work OK for me. But if you're on a high bite track that is smooth and not so big, stock arms will give you a bit more precision in handling.
As far as covering your motor, I wouldn't. I would make sure I took the motor apart more frequently to clean it out. You don't want debris in the bearings and between the rotor and stator.
J_Bone is offline
