SC10 Thread
Old 12-29-2011 | 12:15 AM
  #8641
CoyoteSlash's Avatar
Originally Posted by brent701
I posted the part numbers for the Front Hex parts needed a page or 2 back.
Kit 9883 comes with 2 front hex and 2 rear hex. The rear he will at on epoint cause the wheel to become loose and You will have to run a washer between the axle nut and the rim. I use Jconcepts rear alum. hex's, the front I use the stock plastic ones with small hole drilled in them with a set screw to keep them on. the alum. fronts seem to give you a 1 or so +mm offset. I didn't like that so I ran stock.
You mean they start to eat away at that lip and it creates a gap, right? I'll order up the alum rears. The fronts don't have that big cliff. Makes perfect sense.
That's what I thought with the AL hexes I was finding. I like that drilling into the plastic with a setscrew. That's brilliant.
The CVA's will work. If you are coming from a truck with pins. just remove the axle pin. remove that large round spacer. reinstall the axle pin and than the Hex.
Yeah, FT kit. Want a nice clean transition over to hexes using AE stuff if possible. I used your list for my ordering, And I really appreciate you putting one together.
I run a Gear diff in my SC10 and I just installed one in my B4.1 FT. I like them more. just me though.
I'm considering it because I honestly don't want to hassle with a balldiff. That Thrust bearing is the $^#@&! Devil. Maybe I'll just get a kit and build it as a backup till I get some opinions.
I 'really' want AE to build the T4/B4/SC10 version of the Shocks that came on the SC104x4. What a fantastic shock. Scale it down just a bit and wow. We need big bores like Losi. I know we're doing just fine, but that 22 Platform is a bitchin' setup.
CoyoteSlash is offline
Old 12-29-2011 | 12:50 AM
  #8642
CraigMBA's Avatar
I'd suggest you read this post before you buy any axles.
I use Jconcepts in the rear, and the Proline pieces in the front. If I had Hazard wheels I wouldn't care what axles I have, but I don't, so with the spacers the Prolines are better.
All that's documented, and their own respective problems, in the above thread.
My SC10 2w is just PLUSH to drive. It must feel like an outcast, I never work on it. My 4w gets all the attention, and it's a bucket.
CraigMBA is offline
Old 12-29-2011 | 01:54 AM
  #8643
Now i'm running a little lost. Are you saying the RSspec Sc10 has this bearing crush problem too? Doing a pure AE swap from RSspec will bring it to Zero offset won't it? That's how the RS RtR is at my shop right now? I was under the assumption that the SC10RS was zero offset and all's well. (assuming from visually expecting it myself.)
I think i'm missing something.
Old 12-29-2011 | 05:13 AM
  #8644
Jerz616's Avatar
Just finished building my FT SC10. Love the truck so far. Quick question though. The rear springs are really rubbing the shock bodies. This was the case on my B4.1 also, but as we all have fond using the TLR, or K spring fixed this issue and also made the buggy handle better. Is there such a solution for the SC10? Will the 4x4 BB shocks fit on the the 2wd, or maybe just the springs?
Jerz616 is offline
Old 12-29-2011 | 06:02 AM
  #8645
Just finished mine too. Rubbing baaaaad.
Old 12-29-2011 | 06:11 AM
  #8646
1Fastpede's Avatar
I just finished my kit and its butter. Forgot to order rear bearings for my b44 hubs.
1Fastpede is offline
Old 12-29-2011 | 06:27 AM
  #8647
Asharus's Avatar
Originally Posted by Ryno B4.1
GPM makes one that does not have the spring that needs to be glued
Nice find, they look great
http://www.gpm-parts.com/shop/produc...roducts_id=190
Asharus is offline
Old 12-29-2011 | 07:46 AM
  #8648
brent701's Avatar
He has a good point. I have had my RS for a while now and I have not had any problems with the front Hex, nor has anyone else I race with,.
The Stock RS keep the factory offset. I have ran the Hazard wheels with the 3mm offset they work great,
I also am reading the Proline kit has more slop than the RS stuff,
Just my opinion. Either way will work. I just like the factory parts better,
brent701 is offline
Old 12-29-2011 | 08:57 AM
  #8649
dominick i.'s Avatar
Suspended
I like the p/l hex setup in the front because you can adjust the spindle height.
dominick i. is offline
Old 12-29-2011 | 09:07 AM
  #8650
Pulse_'s Avatar
What are the typical tires you run on :
- clay (track)?
- bashing ?
- street (concrete)?
- astro (track)?
I need a tire that doesn't wear too fast even on hard surfaces but with a good grip in the dust/clay too, do you have any suggestion?
Pulse_ is offline
Old 12-29-2011 | 09:22 AM
  #8651
CraigMBA's Avatar
No. The RS spec pieces use a c clip on the axle for thrust. When you tension the wheel nut down, it puts the inner race into crush, which is no problem.
The Proline piece has no crush bearing (because of the hinge pin location) and works fine as long as you know that and tighten up the wheel nut very carefully. It is harder on bearings.
That's right.
If you use Hazard wheels, the RS stuff is fine and bolts right on. I have a years worth of Rulux wheels and tires so I need the axles to be longer so I can space them out.
The only thing wrong with the AE RS stuff is the axle is too short if you are trying to space it. And the plastic hex is kind of lame.
The only thing wrong with the Proline stuff is the axle has no way to control crush when you tighten it down, and as a result, it's kind of hard on bearings.
Why proline can't machine a notch in their axle for the c clip is beyond me. Why AE doesn't make longer axles is also beyond me. Both of those two running changes would make two perfect products, but between now and then we have to pick our poison.
CraigMBA is offline
Old 12-29-2011 | 10:02 AM
  #8652
Vegatron75's Avatar
Well, I picked up a "lightly" used RS RTR version this week. Wanted to hold out for the FT but this deal was too good to pass up.
The original rear hexes were shot, $5 later and I was good to go.
Raced it last night, ran it w/ the stock esc and 3300kv motor.
Other than accidently turning the D/R down to 80% for the second round everything went fine. I didn't know what was going on in that second round. Dang thing turned like a cruise ship.
Qualified 3rd, ended up winning the A-main. Nice......
A few of the fast guys were absent though, we'll see when they show back up.
Had a good time and got to run a second class, which was the goal. E 1/8 never has enough to run a class...
Vegatron75 is offline
Old 12-29-2011 | 11:30 AM
  #8653
sniperd's Avatar
HEY GUYS JUST WONDERING WHAT GEARING SHOULD I USE IF I HAVE A LRP 5.0 TURN MOTOR ON MY SC10 ALSO WHAT TIRES DO YOU USE FOR INDOOR CLAY TRACKS??
sniperd is offline
Old 12-29-2011 | 11:50 AM
  #8654
brent701's Avatar
I am sorry but with all that listed in your sig and sticking a 5T motor in a SC10. Do you really need to ask that question?
brent701 is offline
Old 12-29-2011 | 12:01 PM
  #8655
I put the rs hex axle up front and use the STRC hex adaptors on all four, love the fact they are held in place by a set screw. I use the SC10 4x4 premounts or rims without any issues.
LeftyAEguy is offline
