SC10 Thread
Old 11-05-2011 | 11:37 AM
  #7891
Anyone see a temp drop from the FT milled aluminum motor plate, or is it just for show? Fighting temp issues a little, curious if it'll help.
LRP SXX stock spec V2, x-12 13.5, geared 20/84 (per LRP), 4 dot timing insert, modes are 3-3-4-0, I think. Motor comes off at 180 after maybe 10 minutes. Esc has fan, comes off at 95! Or, Less boost, more pinion? Speed is perfect right now...
maddysdaddy is offline
Old 11-05-2011 | 11:45 AM
  #7892
bdyche's Avatar
Sounds like your slipper may be too loose or you may have extra drag in your driveline. I would check the screws that go through the transmission case and into the motor plate. Pull the slipper clutch assembly off and check for wear on the inside metal part of the slipper clutch. I was having the same issue and discovered that one of the screws was dragging on the slipper assembly.
As far as temp difference with the FT plate, I haven't had a need for extra cooling, so I can't really tell if the FT plate works better than the RTR.
bdyche is offline
Old 11-05-2011 | 12:25 PM
  #7893
almost done building my sc10 just taking a break because i have no SAE hex drivers so i've had to use the ones that came in the kit so my fingers hurt like a bleep lol
about to start on the shocks here in a minute.
stang is offline
Old 11-05-2011 | 02:15 PM
  #7894
Pulse_'s Avatar
Is anyone racing on astro with the SC10?
I'd like to have a starting setup to try it out
Pulse_ is offline
Old 11-05-2011 | 03:01 PM
  #7895
Cmjomaha's Avatar
Can anyone tell me if there is an actual turnbuckle wrench that will work on on the Factory Team turnbuckles??? None of my regular size wrenches work...
Cmjomaha is offline
Old 11-05-2011 | 03:57 PM
  #7896
20 SMOKE's Avatar
-yes there is a wrench
20 SMOKE is offline
Old 11-05-2011 | 04:42 PM
  #7897
Rampokker's Avatar
Try this one
Rampokker is offline
Old 11-05-2011 | 04:45 PM
  #7898
Hey guys, just got a Ft Sc10. I installed hex adapter setup on the front end and rear end, need to know who makes pre mount tires that will fit.
BIGBOT is offline
Old 11-05-2011 | 05:30 PM
  #7899
bdyche's Avatar
JConcepts makes premounts that work with the SC10, although gluing tires is not that difficult.
bdyche is offline
Old 11-05-2011 | 07:19 PM
  #7900
truck is done but im having trouble truing up the steering any tips?
stang is offline
Old 11-05-2011 | 07:45 PM
  #7901
sc10rr's Avatar
anybody having good results with the gear diff and racing indoors? i've been using the ball diff and always have but im curious as to getting the gear diff to be just as capable.
sc10rr is offline
Old 11-05-2011 | 09:12 PM
  #7902
I just changed back to a gear diff and so far so good. I got tired of rebuilding the ball diff so thought I would give the gear diff a second chance. Hard to notice that much of a diff between the two in my opinion. Got a feeling you will experience the same if you try a gear diff.
Murray100 is offline
Old 11-05-2011 | 09:46 PM
  #7903
LRP SXX stock spec V2, x-12 13.5, geared 20/84 (per LRP), 4 dot timing insert, modes are 3-3-4-0, I think. Motor comes off at 180 after maybe 10 minutes. Esc has fan, heatoff at 95! Or, Less boost, more pinion? Speed is perfect right now...
I installed the FT plate on my RS (after running the standard one first), and I noticed a mild drop in temps. But at the same time I swapped plates, I also used Artic Silver thermal paste (stuff I use on computers) between the motor and the plate, so that too may have contributed to a slightly cooler running setup. It was enough, in my case, to pull my temps down from the dangerous 180's to the merely quite hot 170's. Granted this is with 105 deg. outside heat here in Vegas. That darn Reedy 3300 does get toasty, especially on stock gearing. Would I buy it again? Nah. I'd first do the thermal paste, THEN add it maybe. A fan or sink on the motor itself would likely work better, if you could ever get one in there.
I wouldn't say I'm a successful racer, I'm just a club racer having fun and occasionally getting somewhere near the top of the heap by the end of a race, occasionally not. I run the RS gear diff (more coarse gears than standard SC10, supposedly more durable.) I've been fooling with different viscosities and have worked my way down from 10k, to 7k, then 5k, and I just put in 3k and I'm giving that a try tomorrow.
The track: a very loose running, somewhat packed dirt/clay indoor (sometimes pretty wet) place. I quickly went down from 10k to 7k after raceday one with this truck, that was just too much all around though it worked well on the concrete outside. 7k was better but still way too strong, and 5k definitely got in the ballpark so I kept that in for 4 race weekends. I am hoping that 3k puts me in the sweet spot for this loose track, while still keeping me from diffing out. If you've got significantly more grip, you might want to mess with the 5k to 7k fluids.
What's cool about a gear diff is you can make these adjustments, though it sure takes a while to get to the trans, so don't expect to change fluids in-between heats.
Lansonfloyd is offline
Old 11-05-2011 | 10:42 PM
  #7904
Cmjomaha's Avatar
Well thanks!! I got the kit used and it did not come with the kit tools. I have 3mm, 4mm and 5mm and non fit. Just found that strange. I search this thread and did not find a post about it. Google came back with some other boards talked about it being 3.6 which i had not seen before. Sorry for bothering ya with a stupid question....
Cmjomaha is offline
Old 11-05-2011 | 10:46 PM
  #7905
Cmjomaha's Avatar
Originally Posted by Rampokker
Thanks for the response. Was not sure that one would work since it says it fits 1/8 turnbuckels. I will give it shot...
Cmjomaha is offline
