SC10 Thread
Old 11-30-2011 | 02:26 AM
  #8296
RCW
Originally Posted by idrummerboy13
What are you using to keep the back of the battery in place?
RCW is offline
Old 11-30-2011 | 03:29 AM
  #8297
idrummerboy13's Avatar
the speedo is mounted behing it, behind speedo will be foam.
under battery they is a ballast which weighs 3/4 of my 5000 mah .
thanks wild cherry for the idea. I will be try racers edge hubs .5.=]
today adding ft buckles possibly ft and rear team shocks =]
-SC10 FT.
idrummerboy13 is offline
Old 11-30-2011 | 07:17 AM
  #8298
kc_nitro_rc's Avatar
Originally Posted by brent701
Is the shock shaft different from a FT V2 shock and the V2 shocks in the RS RTR ? Or is just the body different, FT being threading RS not?
I have the FT shocks on my RS truck and If the shafts are the same., you can save a lot of money by just buying the threaded bodies, instead of the whole shock kit. But having spare shocks is nice
The FT V2 shocks use a different 'rebuild' kit. Actually all you would need is fresh o-rings so maybe it's no big deal. I thought about buying the RS shocks as a back up. Not sure if they will mount up the same as the pretty V2's.
kc_nitro_rc is offline
Old 11-30-2011 | 07:45 AM
  #8299
Sprinkler's Avatar
How are you guys putting your weight behind and under the battery?
It looks like there is room for one 1/4oz weigth under the battery. Any more then that and you can't get the battery strap installed. I have mine all stacked up at the very back of the battery tray. Pretty much under the rear shock tower.
Sprinkler is offline
Old 11-30-2011 | 09:07 AM
  #8300
Hey guys,
What is everyone using for bump stops in the shocks to prevent harsh bottoming out? I can't seem to find anything.
Chris
ravencr is offline
Old 11-30-2011 | 09:12 AM
  #8301
piece of fuel line or a couple o rings?
vw addict is offline
Old 11-30-2011 | 09:22 AM
  #8302
I like the idea of the esc centrally mounted behind the battery, but what about mounting the rx centered? Like on top of the battery strap? Would that throw off the c.o.g. to much? I mean my rx weighs next to nothing.
Old 11-30-2011 | 09:35 AM
  #8303
brent701's Avatar
The V2 shocks in the SC10RS have the same style o-rings and rebuild as the FT V2 shocks. Just the FT shocks have a threaded body. My question was based I guess to try to save people money that bought the RS RTR truck and want threaded shocks, I think you can just buy the Threaded bodies instead of the whole shock kit.
brent701 is offline
Old 11-30-2011 | 09:41 AM
  #8304
20 SMOKE's Avatar
Hey guys,
Chris
you can use some pack in the shock or put a small piece of fuel tube on the shock shaft
20 SMOKE is offline
Old 11-30-2011 | 09:43 AM
  #8305
Is there a specific fuel tube I need to get from the hobby store for the stock SC10 shocks?
Chris
ravencr is offline
Old 11-30-2011 | 09:53 AM
  #8306
Wild Cherry's Avatar
Tech Legend
bump shims or fuel tubing, ect ..
Not !
If you are bottoming out or slapping hard landings ?
#1 Check the ride height first , too low is not good .
start dog bones level
#2 If the ride height is good and you are still slapping on landings ?
try a 1/2 w thicker oil first or a smaller piston size
Still not happy with the landings ?
Go a stiffer spring on the rear ...
Wild Cherry is offline
Old 11-30-2011 | 10:01 AM
  #8307
Not !
So, do I want to start out as soft as possible and work my way up with oils and spring rates? I can't see how folks aren't bottoming out nonstop with these trucks with as little spring rate and think oil they're using. To me, I've never raced a real vehicle without bumpstops, in fact most desert trucks have aftermarket air bump stops and position sensitive valving with multiple spring rates, so I'm wondering how to set these little trucks up without all of that but still with good performance without slamming the ground off every jump.
Chris
ravencr is offline
Old 11-30-2011 | 10:49 AM
  #8308
Get another foam pad, cut it like your current one. Then trim some foam out of the under side. I'm going to try that.
Here is a crude diagram of a side view-
___________
|........ ____|
|_____|
This way it is out of site and shouldn't interfere with your current setup.
Old 11-30-2011 | 10:51 AM
  #8309
nadan805's Avatar
I don't like running my rx without a box for protection. I guess I could run a balloon over it and put it on the servo or battery strap. I doubt at my level of driving it really matters.
nadan805 is offline
Old 11-30-2011 | 12:19 PM
  #8310
Sprinkler's Avatar
___________
|........ ____|
|_____|
Why not just stack it up all together in the very back of the radio tray and then butt your battery against that?
BTW...I don't use bump stops on my shocks and I have never had a problem.
