SC10 Thread
#5897
Looks like the chassis is different in the back where the box fits. No web there where the box sits. The steering block looks better like they made the bearings wider than Pro-line and hopefully the axle fits the bearings better too.
#5899
I converted my FT T4 to a SC10 and I really like it. I have raced four different SC10 over the last couple years. Personally for me the shock made the biggest difference. With the rtr shocks I would redo them after three qualifier and air in them. I bought TC4 bladder caps and it keeps the shocks more consientant over the qualifers.
#5902
One thing to check on the rtr shocks is the spacer tube that goes between the o rings. if that spacer is too long it will squeeze the oring causing premature leakage. In my first SC10 kit, 3 out 4 tubes were too long. I trimmed them down just alittle and no leakage. Use the AE green slime to assembly the seal assembly. I love the bladder caps. help to keep the air out. the shock profile doesnt change as much with use.
Check this about the debate over bladder shocks vs Emulsion Shock
http://www.rctech.net/forum/electric...er-shocks.html
#5903
I'm starting to think about shocks because i noticed a little bit of moisture at the arm attachment points at the rear, and AE shocks are pretty well-known for leaking. I've only run 2 packs through mine at a moderate pace, but the track I run it at does have a reasonably rough surface.
#5905
#5907
From: Norwood, OH...and CCRCR and The OhioRCFactory
The FT shocks are easier to build consistently, don't leak as bad as the more modern, old-style shocks, and are faster/easier to rebuild when the time comes. Not to mention they have TiNi coated shafts.
Spoken like somebody that has never owned both the stock SC10 RTR/basic kit shocks and the V2s
..I dont really see a need to upgrade them imo..
