SC10 Thread
Old 02-07-2011 | 11:50 AM
  #5566
Cameron Kellogg's Avatar
Originally Posted by nightc
U heard some bad things about AKA hex conversion, especially the long nut in the center. So far so good?
I use the B4.1 axle in the front with the button head screw to hold the fronts on. On the rear the nut is really long so I took a 3mm nut and drilled and taped it for the 8/32 axle. This picture does not show but I use the nuts that are covered now. The only problem I have had is that they use a 3/8x5/16 bearing on the out side and it seems to not last long on high bite tracks. I was shimming the bearings so that they had zero slop and believe that was what killed the bearings. Recently I leave the bearing shim out and with a little play now the bearing is lasting a lot longer.
Cameron Kellogg is offline
Old 02-07-2011 | 12:21 PM
  #5567
T-BirdJunkie's Avatar
From: Norwood, OH...and CCRCR and The OhioRCFactory
Originally Posted by Firefox
Anyone use or feel a need for the RPM shock towers, there's a front one available now too ?
Nope. Haven't broken one on either end. Taken some hard hits, too.
T-BirdJunkie is offline
Old 02-08-2011 | 08:46 PM
  #5568
What's the trick to building an Associated shock that does'nt leak?
Rob.......
Robio is offline
Old 02-08-2011 | 09:15 PM
  #5569
I have RE-built all 4 shocks 3 times now, plus the original assembly. I have not used a rebuild kit, all original orings. I have ZERO leakage.
Im wondering if a lot of people build shocks in haste? I like to just take my time. Also I tighten the caps as much as I can by hand, then cinch it down more with a wrench/screwdriver
I have had 1 shock leak on my 18t, never on my RC10GT or my SC10
Hemi Killer is offline
Old 02-08-2011 | 09:17 PM
  #5570
I broke a front shock tower. It broke the corner off where the ball stud screwed in. I had to move the rod ends inward because the shop had no towers in stock. I actually noticed more stability this way, so I'll leave it for a while.
I will be buying a stock shock tower, not RPM.
Old 02-09-2011 | 12:01 AM
  #5571
mickeymouse93's Avatar
Rob.......
Buy the V2 shocks
mickeymouse93 is offline
Old 02-09-2011 | 06:23 AM
  #5572
UK.hardcore's Avatar
Rob.......
Don't fill it.
UK.hardcore is offline
Old 02-09-2011 | 06:45 AM
  #5573
KINGZJ's Avatar
WHo has the best deal on purchasing a factory team sc10 as of now?
KINGZJ is offline
Old 02-09-2011 | 07:48 AM
  #5574
JEFFs SC10's Avatar
I scored a brand new one off ebay with losi ball ends for 140.
JEFFs SC10 is offline
Old 02-09-2011 | 08:27 AM
  #5575
Driver86's Avatar
Hey guys, I need a new screw set for my SC10. This one here seems a bit excessive http://www3.towerhobbies.com/cgi-bin...?&I=LXXMP4&P=7
Anybody know where something cheaper/better or am I better off just trying to get the individual screws at a hardware store?
Driver86 is offline
Old 02-09-2011 | 08:28 AM
  #5576
You definitely don't want the RC Screwz stainless junk. Tony's Screws should have a good kit of black oxide screws.
Also if you want to write down which and how many of each screws, you could put in an order with Fastenal.
Old 02-09-2011 | 09:04 AM
  #5577
Wild Cherry's Avatar
Tech Legend
Your local race facility...
Wild Cherry is offline
Old 02-09-2011 | 04:09 PM
  #5578
primo86gt's Avatar
Default Leaking shocks
Rob.......
If your overfilling them thell leak everytime. If you push the shaft in and its pushing back out, its overfull.. (cap tight and no spring)
primo86gt is offline
Old 02-09-2011 | 05:31 PM
  #5579
Thanks for the info.... Don't think I'm over filling them. Have 0 rebound after assembly. I did'nt build them to begin with so maybe I should start from total tear down and rebuild..... Or maybe try the "no fill" option
Rob.........
Robio is offline
Old 02-09-2011 | 06:41 PM
  #5580
???E-Racer's Avatar
+1 on Tony's Screws. But better yet I have a hard time stripping the stock
steel screws with a good tool set. People in my area have used the Tony's
Screw kits with good results.
???E-Racer is offline
