SC10 Thread
#7067
You have the front caster blocks on the right side,I run 32.5 front 30 rear.I also run the battery 1 foam from all the wAy foward.try blue springs up front and silver in rear
#7068
[QUOTE=dirt_oval;9614729]Really both entry and exit. I am running suburbs on the front (green). Its a clay track, with medium to low traction most of the time.[/QUOTE
Try some enduros up front. I always feel the suburbs make my truck push bad
#7069
I had this really bad noise coming from my rtr today. I thought it was the slipper so I tighted it up and the noise got worse until the truck stopped. I figure it was the stock diff. So know I have to replace it. What kind of diff do you recommend, ball or gear, stock or after market.
Mike
Mike
#7070
Mike
Mike
#7072
I think it is the diff internal gears, It fells really rough if I turn on side of the diff and then smooth on the other side. Everything else seems ok. My son races with this truck, he's a little hard on them so I thought the ball diff maybe a little difficult to keep smooth.
#7075
Thanks, I was actually thinking of a lower gear, I'll try that and monitor my temps......... I also hope to make it to west coast as well as OCRC before the end of the year...... Any tips on tires or setups for westcoast? Thanks
#7077
Thanks I have gold barcodes for now which works really well at my track so I'll try them out there. If not I have rear suburbs I can switch them out to. Hopefully if work allows I'll be there sometime next month.....
#7078
I have suburbs that are really good,still trying to get rebars to really feelplanted,,wishbones and the trusty gold barcode.what track you normally run on?
#7079
What are good days to run at westcoast, and any rules etc I should know about beforehand?
#7080
[quote=nitro0619;9614983]
However, most of us guys run the Suburbs, and theirs steer more then mine, so I figured it has to be in the setup. I am one of the only locals that is running stock at the moment, so I really can not ask for a lot of help since they are all running mod!
Also, does anyone have a chart or something of all the gearing options that will work? I am looking for an equal amount of speed and tourqe from my 17.5. I though about going with a 69 spur with 35 pinion which gives me the FDR I am aiming for, but not sure if I can manage that!
