SC10 Thread
#4068
anybody put any weight up front? i have a old 5 cell nimh pack i stuck in the front bumper with a zip tie but can't get to the track till psycho. oh well, i fi don't like it i guess i can just yank it.
#4069
We run mostly clay here in Indiana which doesn't tend to blue groove much but does provide good traction even when its dry. I have not changed from the stock a-arms and they have held up very well on an 1/8 scale track.. My current setup is as follows:
Stock SC10 fronts
Proline Bowtie M3 rears with stock foam
Novak GTB with Novak 13.5
FT shocks 35 wt Gold springs front, 30 wt Blue springs rear
Losi 1 deg rear hubs and Losi rear hinge pins
-1 deg camber on all 4 tires
1 deg toe out up front
Battery in stock position
2oz weight around battery foam in rear
Long camber links in the rear
AE 3000 wt oil in the diff
Jconcepts under body tray
I won our Dueling for Dollars points series with this setup. The thing with these trucks is THROTTLE control. If you don't have any you need to practice until you get some or they will be a hand full no matter what setup or motor/esc combo you have.
Stock SC10 fronts
#4070
I've been running the RPM front brace for a couple of months now. It works great. Solid as a rock. I highly recommend it.
Agree with the Losi rear hubs. I've got both the 1-degree and 2-degree ones, depending on track conditions.
I split my battery foam, and run the battery about 3/4" from full back. I've got 2 oz. of lead under the rear battery foam. No added weight up front. These things have plenty of steering without adding weight there.
Good luck with your SC10
#4074
Simple, strong, lightweight and will hold your truck together even if you have already broken it.
My truck is still broken and held together with the original piece that I started with.
Mount it under the bumper.
If you like it you can pm me and I'll ship one out the same day.
#4075
