SC10 Thread
#4051
I have heard that to fit the RPM front arms you need to use a different outer hinge pin. Is this true? Is there a way around that?
#4052
I got the extra hinge pins when I got my arms..just get them as they are cheap..just put rears on and they take the std pins.
#4054
I am running a Hobbywing 13.5 non sensored and plenty fast enough on our dusty slippery clay track.
#4056
Wow a 5.5 in an SC10 will be a handful even turned down.
Never had any success with Novak..sent a GTB back when it was new..had an 8th system which blew in my ERevo..got them fixed under warranty no problem but put me off...saying that do have a Novak Havoc in my F1..only because it was cheap and even it randomly goes into reverse some times
#4057
#4058
It was in the early release of the GTB and sorry cant remember what motor it was... I am used to gear diff in 8th scale and Durango and they dont loosen off and change like ball diffs..harder to change setting as you need to change oil but havent bothered with SC10 and still has grease in it as RTR I got and stll feels super smooth and may have a play with some oils but dont know if it would make a marked difference as goes fine.
#4059
Do u remember with sub c and lipo, the difference weight? I wonder if poeple think adout that still? I had my t4 battery brace loaded with lead and the truck felt fine. I wonder if the sc10 was made, or weight with sub c battery packs with it was produced. Or did they use lipos in it for testing?
Sometimes I think of some of the dumbest $h1t!!!!!!!!!!!!
#4060
[QUOTE=mini696;7077997]I have heard that to fit the RPM front arms you need to use a different outer hinge pin. Is this true? Is there a way around that?[/QUOTE
Or cut the stock ones down a bit with a Dremel.
#4061
Contemplating buying a T4 FT for parts and try and sell off the chassis, bodyshell, wheels etc. I think the main reason, is probably that, to buy even the threaded shocks is almost 50% of the cost of buying the above kit.
Only problem is that the T4 isn't that popular here in the U.K.
Are the threaded shocks worth the money, or is there something better out there - my mate suggested losi shocks?
#4062
#4063
ben
