SC10 Thread
Old 10-29-2009 | 02:46 PM
  #3151
I run split six rims because they give me more control in the air. I already have enough motor...
Krio is offline
Old 10-29-2009 | 03:08 PM
  #3152
R/C Tech Elite Member
I run the Split Six Bead-Loc wheels and I really like them (http://www.myrcbox.com/?p=1837). They are a little bit heavier than stock wheel but their weight add more traction.
Sylvain is offline
Old 10-29-2009 | 03:47 PM
  #3153
z50king's Avatar
i have bowties on split six beadlocks. is anyone else having the back side of the tire come out of the bead lock? small sections came out a 3-4 times last night, and during one run the entire backside of the tire was off the rim. the 6 screws on the plate were all tight
z50king is offline
Old 10-29-2009 | 03:48 PM
  #3154
Originally Posted by Retloh
For those adding weight to the rear, Proline Split Six rims add 1.2oz per side.
Associated SC10 wheels/Proline Bow-Tie SC tires: 3.8oz. each
Proline Split Six wheels/Proline Bow-Tie SC tires: 5.0oz each
I can't glue the Bow-Tie tires to the Associated rims for the life of me, keep getting some severely unbalanced tires due to glue getting where I don't want it, so I switched to the Split Six rims. Haven't been to the track yet to see the difference the weight makes, but I haven't added any weight to my chassis yet either.
The only thing the spit six proline wheels do is add rotational weight which is no good and robbs power from motor and battery and does nothing when it comes to someone wanting to add weight to the rear for traction.
airwoods is offline
Old 10-29-2009 | 03:53 PM
  #3155
balistic's Avatar
And that rotational inertia increase acts like a big heavy flywheel and aids in low traction situation.
balistic is offline
Old 10-29-2009 | 04:43 PM
  #3156
as you well know i have way more motor than you. i have yet to have a tire even come close to coming offf the bead.
its all about getting the tire on straight when you assemle it.
ill do them next time for you and we will see if its installer error.
p.s.
take a peek at what i drove for last nights open short course @ OCRC....
http://www.youtube.com/watch?v=cPQo2NyRSDI
p.s.s.
its a 13.5 motor
Pimpin is offline
Old 10-29-2009 | 06:26 PM
  #3157
porkchop's Avatar
dose any one make a better batt strap for the sc10?
porkchop is offline
Old 10-29-2009 | 06:32 PM
  #3158
trx450racer174's Avatar
Better or different???
STRC makes an aluminum one.
AE has a FT one thats carbon.
I have a custom one also p.m. me if you want one.
trx450racer174 is offline
Old 10-29-2009 | 06:40 PM
  #3159
JSmall's Avatar
p.s.
http://www.youtube.com/watch?v=I0eq1X3dmqQ&feature=sub
p.s.s.
its a 13.5 motor
That track is sweet! Matt your truck is hooked up Obviously you're a great driver too.
JSmall is offline
Old 10-29-2009 | 06:45 PM
  #3160
trdsupra88's Avatar
The AE strap lets you move the battery around alot easier...
trdsupra88 is offline
Old 10-29-2009 | 06:56 PM
  #3161
Arigato's Avatar
Any added weight to the wheels adds to unsprung weight which confuses the suspension. In addition, that weight transfers more energy and stress to those components immediately around it. If simply putting heavier wheels on a race truck would increase performance, wouldn't the TORC trucks and Lucas Oil race trucks just run solid steel wheels instead of aluminum? Any added weight to a performance vehicle must be as close to the center of the chassis as possible.
Arigato is offline
  #3162
wayboarder's Avatar
p.s.
p.s.s.
its a 13.5 motor
you mean this one?
wayboarder is offline
Old 10-29-2009 | 07:18 PM
  #3163
balistic's Avatar
It does exactly what I said, it helps in loose conditions to keep the tires from spinning up as fast when traction is lost.
I didn't say anything else. I didn't say unsprung weight is good.
By the way have you ever held one those Aluminum wheels? They are not light, Aluminum is used for many reasons but at the end of the day in off road beadlock wheels they are just as heavy and in many cases weigh more than a steel wheel.
To your last point weight is added anywhere a part fails, sprung or unsprung, center of mass or lug nut. Durability is king when attrition is as big factor as in off road.
balistic is offline
Old 10-29-2009 | 07:26 PM
  #3164
The factory team one is the best design I've seen so far. Simple too. . . cut your foam spacer block in half.. add this strap . .
http://67.199.85.166/main/productdetails.php?text=9851
then you can adjust the battery forward, middle, and all the way to the rear.
Brandon Powell is offline
Old 10-29-2009 | 07:39 PM
  #3165
porkchop's Avatar
i gut the tabs of the stock strap and can move it around
porkchop is offline
