SC10 Thread
Old 04-01-2009 | 02:16 PM
  #16
ckaspar's Avatar
What electronics are you planning on running? I am thinking of getting one, if I can, and want to know what you/others were planning on running.
ckaspar is offline
Old 04-01-2009 | 02:22 PM
  #17
no bearings for the steering you would think they would throw those in. it says it includes bearings....... thanks for the heads up
jombo is offline
Old 04-01-2009 | 02:25 PM
  #18
trdsupra88's Avatar
I just pooped a little...thanks for the build pics...
trdsupra88 is offline
Old 04-01-2009 | 03:21 PM
  #19
Default Bag B Assembly Complete
I have completed the Bag B Parts Assembly. Everything continues to go together well. No missing small parts. Even though I got a little nervous when I only had 2 of those potentially flying e-Clips in the bag. Not to worry, I always have a spare bag of them just in case.
The thing I really like so far is the Hex driver ball studs. The AE gang really scored with these. Especially once you get all the bumpers added. Maintenance and Setup changes are going to be a breeze.
I went ahead and added the Factory Team Hinge Pin Brace and Ti-Turnbuckles.
#9665
#1283
You may also want to have plenty of Ball Stud Washers so you can adjust the geometry, bumpsteer, ect as you build. Although some steps in the Manual call for a certain number of spacers (ball studs), this kit as well as the FT T4 I recently built, didnt contain some of them in the kit.
Pics of the completed front assembly, and Nerf Bars added to the chassis. This carries you thru Step 8 of the build.
Up next Bag C. The Gear Diff and Transmission assembly.
To Be Continued........
Attached Thumbnails SC10 Thread-front-assembly-complete.jpg   SC10 Thread-nerf-bars-added.jpg
JDCrow is offline
Old 04-01-2009 | 03:24 PM
  #20
The Bushings are in the Steering Rack.
The Transmission, Front Wheels, Rear Axle Carriers have Bearings in the Kit.
JDCrow is offline
Old 04-01-2009 | 04:03 PM
  #21
nc-hopsing's Avatar
JDCrow....are the arms on your SC10 the same as the T4 arms? Looking at the pic of the front end, they look like they might be the same?
nc-hopsing is offline
Old 04-01-2009 | 04:24 PM
  #22
Suspended
where did you get it from...nobody has them in stock
i am cornholio is offline
Old 04-01-2009 | 05:17 PM
  #23
Yes. Part #7446 Fronts. Part #7448 Rears
Kit comes with the GT2 25 Degree Caster Block (#7919)
JDCrow is offline
Old 04-01-2009 | 05:36 PM
  #24
Default Not much left to do
Well after this post, there is not much left to do.
Left to do:
-Add Rear Hubs and Driveshafts
-Build Shocks
-Install and Fine Tune Electronics
-Install the Battery retention strap
-Assemble Tires/Wheels
-Final Chassis Setup
-Paint the body
The assembly has been really smooth. No missing or damage fastners. Everything needed to complete a step is individually packaged.
Guys who have an SC8, the SC10 mudflaps are exactly the same part.
For guys about to build, if you have fumbly fingers you may want to make sure you have extra hardware (plain washers, screws, etc), because the parts included are the amount necessary to complete the task.
When you get to the transmission assembly in Step 7, leave the rear bumper lower brace loose. You can snug it once your are ready to finish Step 9.
Off to get something to eat.
Attached Thumbnails SC10 Thread-transmission-bag.jpg   SC10 Thread-gear-diff-assembled.jpg   SC10 Thread-more-complete-gearbox.jpg   SC10 Thread-gearbox-complete.jpg   SC10 Thread-tranny-halves-ready-close.jpg
JDCrow is offline
Old 04-01-2009 | 05:41 PM
  #25
More pics since the limit is 5 per post
Attached Thumbnails SC10 Thread-rear-assembly.jpg   SC10 Thread-rear-bumper-assembled.jpg   SC10 Thread-rear-bumper-assembled-2.jpg
JDCrow is offline
Old 04-01-2009 | 06:01 PM
  #26
Crawler's Avatar
Do the instructions say anything about the yellow gear material?
Crawler is offline
Old 04-01-2009 | 06:09 PM
  #27
I think if you look at his sig he runs his own hobby shop.
"JD Crow's Miniature Motorsports"
big deee is offline
Old 04-01-2009 | 06:14 PM
  #28
xDaRReLLx87's Avatar
Be sure to always use a nut the size of the height of the # of washers. This will prevent your ball-studs from flexing and breaking. This extra step ensures great life. Keep the building process up
xDaRReLLx87 is offline
Old 04-01-2009 | 06:32 PM
  #29
I didnt see anything. Kurt or someone may be able to elaborate on that one.
JDCrow is offline
Old 04-01-2009 | 06:43 PM
  #30
KO Servo
Tekin RSPro Speedo
Tekin Redline 17.5
Futaba FASST Radio System
Orion LiPo
JDCrow is offline
