HoBao Hyper 9E thread
#1111
Modified Mblox for Hyper9e
Thanks for the heads up....The stock Hyper 93 mount works with a 15t pinion and larger. I run a 1900 tekin on 4s and a 15-16 is the right pinion....The mount should work for what all 6 Hyper drivers at our track run.
Here is a pic from my cel phone. That is a 16 tooth pinion on there.
I used a Ridgid Oscillating EDGE/Belt Spindle Sander. Started with 80grit and finished off with 220grit paper. Heres a link for the sander.
http://www.ridgid.com/Tools/Oscillat...r/EN/index.htm
#1112
not really a designer but alittle something to prevent chassis flex under the center drive shaft. this chassis doesn't really have chassis braces,i suppose the battery box is the chassis brace.... but if u cut on it like i did to fit wider batteries then it weakens it
#1113
My own mod seems to help the similar issue. Glad to see someone else noticed the issue I had. Sure helped my car out a bunch with minimal alteration to the buggy. Thanks 2dialed for the update, you really seemed to fix the issue. Great work!
Heres a pic of mine with the awesome Elite RC motor mount.
#1114
yeah, i got to see brandons mounts when he came down to revelation for thanksgiving... very nice machine work but it looks like he made it to fit the nitro version with the center diff. only 2 screws to the chassis instead of 3. at least with the nitro chassis u can go 4mm chassis extended and regular chassis braces. do u guys run over at union city? have u ever been to lakeport
#1115
Really nice mod! I myself was not happy with factory chassis flex, mainly the rear chassis flex. Between the center diff and the radio tray, too much longitudinal flex with in my opinion causes excessive center drive train wear.
#1116
My mod consists of a 4mm turnbuckle and some ball ends from a torque rod off my Kyosho Inferno GT. A truggy steering turnbuckle should work with a Kyosho torque rod ball stud anchor for attaching to Hyper9e radio box plate.
Something like this, but not this exact one.
http://www.amainhobbies.com/product_...Torque-Rod-Set
Take a look to see if you have one lying around that is the right length.
I had to cut the turnbuckle a little to fit to length.
#1117
The 3rd screw was intended to keep the motor mount stable due to the split diff design, the 3rd screw actually hinders the horizontal/side to side flex that a buggy needs, what the 9E lacked was a lateral brace which your mod will take care of..
You & Titotime are on the right track with reducing the lateral flex..
#1118
hi there,sorry bit off the subject but does anyone know who sells the cnc rear support brace for the hyper 9e,its the brace above the centre diff.......
#1120
none on specialrc cain,any more idea,s,
#1122
thanks guys,goin to have to order one from specialRC because nobody does these in the uk,going to cost me a small fortune but HEY,THANKS AGAIN,
#1125
As far as the motor mount is concerned, it's best to find a good support for the motor, or at least get some dense foam to put under there.
Just my $.02
