HoBao Hyper 9E thread
#1141
nice one crashtestpilot,is that just a optional hyper 9 wing mount-h89032-,also i see some kind of motor support,what is it or is it home made?thanks mate
#1143
Hi,
today i received my XeRun 150a + 4274sl (2000kv) combo. I've just finished installing everything. The cables are a bit on the long side, i will shorten them in the near future. I managed to install the 14T pinion without making the motor touch the cup of the center differential.
The car, ready to race, weights 3.765kg with 2x 2s 5000mah 25c hardcase lipo.
Just to drive the wife crazy i tried it in the hallway and at low speed the esc feels smooth and is not cogging.
Now i just have to wait for it to stop snowing...
Which is the most needed/suggested mod? Titotime's rear brace mod ora motor support?
Mattia.
Mattia.
#1145
tq hyper 9e, last feb.7, manila philippines
heat2:
www.youtube.com/watch?v=hlF5jHXoMGk
heat3:
www.youtube.com/watch?v=ETzBoNA3Ofo
heat2:
heat3:
#1147
I think that's the right part, in the states it's 29032 as shown here:
http://www.nitrohouse.com/catalog/pr...ducts_id=20221
The motor support is home made, low tech but functional and no cost.
I used the hard plastic handle from a small wire brush. It had curved indents (the finger grips) on it that gave me the idea. I found a drum sander the diameter of the motor can and opened the indent up to perfectly fit the motor. A bit of sanding on the backside until it wedged beneath the motor perfectly, drilled and tapped beneath to use the stock mounting holes to hold it in place.
#1149
when using that wing mount,is the wing held on using body pins or can you screw it to the wing mount?thanks.
#1150
#1152
anyone having any trouble with the upgraded rear shock tower i bought it so i could fit the lower arms but have bent 2 of them so far
#1154
i bent one in my first car but i straightened it then a few weeks later i bent the one in my second car maybe its my driving im not sure just curious to see if other guys have had a problem
