HoBao Hyper 9E thread
#1098
I looked at your pics and I see the difference and why mine is wrong. Reference to your pic on the left..The Mblox motor mount on your is smaller...( less material on the left side of the silver part, the screws wholes on yours are closer to the mount.)
On mine there is 4 mm from the outside edge of the silver mount to the edge where it meets the black mount. I think I got the wrong one.
Does your center diff spur rub on the black mount ? Mine does as well. I had several guys look at it and all say , its wrong !!
#1099
#1100
My Mblox is a standard size which usually works for most gearing but the 9E seems to have a really small center spur 40T which is not the norm..Titotime modified his mblox by sanding it down on one side..
On another note, since it was such a crazy week for me I accidentally forgot to include a flange bearing to replace the one on the diff thats why your spur is rubbing, I sent the bearing to you separately the following day so you should get it tomorrow, I apologize for not giving you a heads up..I had no idea the mount would to get you that quickly..
The only way to fix the mesh problem is to either change the gearing or sand down the one side..
Please call or email me if you have any concerns or questions..
once again I apologize, hope it didn't ruin your day at the track...
#1103
Here is a pic from my cel phone. That is a 16 tooth pinion on there.
#1106
Thanks for the heads up....I dont own anything to sand it down. I have an exacto and thats it. I thought it would bolt up. The stock Hyper 93 mount works with a 15t pinion and larger. I run a 1900 tekin on 4s and a 15-16 is the right pinion....The mount should work for what all 6 Hyper drivers at our track run.
#1107
Tech Legend
I think having MBlox that are shipped for the Hyper 9E modified already would be an adequate solution, at least for me.
However, I would want to know if for future runs (ie- current stock is sold) of the MBlox, will these now be cut so they are universal for all vehicles including the Hyper 9E or will they still need to be modified first?
Also, what lengths are the screws? (would want to order extras, bad tendency for parts to get feet and walk away)
#1108
Future Mblox will remain the same, if I ever do make a new batch of 9Emounts then I will make the same amount of Mblox to match it..
I include 2 sets of screws 3x10 CH & 4x10 CH
