Team Associated RC8Te Thread >
Old 06-20-2010, 03:57 PM
  #271
Dan
Dan's Avatar
Trader Rating: 75 (100%+)
I would call up some of the smaller online shops to see if any are in stock. Most likely there are quite a few on shelves or in the warehouse. The bigger guys, like Tower, are definitely out of them.
Dan is offline
Old 07-09-2010, 07:36 PM
  #272
OG RC 10T's Avatar
Trader Rating: 41 (100%+)
Can some one post track set up's. I havent been able to find them on rc10.com or here.
Im looking for differnt / more common diff oil combos, as well as shock oil weights too.
Just to get a rough idea for a better starting point.
OG RC 10T is offline
Old 07-09-2010, 09:53 PM
  #273
I converted my SC8 with some parts from my nitro RC8 to brushless
Its geared at 46/15 with the 2200 MMM combo.
the motor is running hot, around 170F after 10-15mins.
Should I gear down or get a heat sink?
I run on a pretty long track, I have a 56T spur from my nitro RC8 but according to the speed calculator I don't think it would be fast enough for my track with the 56T.
Anybody running a 56T spur?
funkhouser is offline
Old 07-10-2010, 04:34 AM
  #274
you should be using pinion sizes around 17-18-19. I would start with 18.
Stick with the 46 spur.
bohdi is offline
Old 07-13-2010, 11:45 PM
  #275
spunkysandoval's Avatar
Trader Rating: 125 (100%+)
Here is my RC8TE
spunkysandoval is offline
Old 07-13-2010, 11:56 PM
  #276
kman16jr's Avatar
Trader Rating: 56 (100%+)
Default conversion
That's a really clean conversion.Nice.
kman16jr is offline
Old 07-20-2010, 07:30 PM
  #277
rcracenut's Avatar
Trader Rating: 52 (96%+)
Getting a RC8TE this week. What is the best set up for this truck?
rcracenut is offline
Old 07-20-2010, 08:12 PM
  #278
prettyboy's Avatar
Trader Rating: 59 (100%+)
If its a kit your getting I would try the stock set up first and go from there.
I running the stock set up with just a few little changes.
Front&rear shock oil = 35wt
front diff=7,000
center diff=15,000
rear diff=5,000
rear camber set 0deg with camber link at the inner hole on the rear hub
front camber -2deg
toe is -2deg
running FT steering knuckels,rear hubs, f/r threaded shocks,carbon fiber f/r shock towers,short wheel hubs
This set for me is very good on smooth and semi rough tracks with a light loom on it . Hope this helps some.
prettyboy is offline
Old 07-21-2010, 05:24 PM
  #279
rcracenut's Avatar
Thanks!
Old 07-22-2010, 12:46 AM
  #280
1BLADE1's Avatar
yea, would agree with PB the stock set up is pretty good to start.....
the main thing it seems like to me with the AE cars now is the "Tires"
so check what most of your "Locals" at your track are running, this will help allot
and like PB said, you might have to do little changes in your set up
for example on both of mine i have a RC8TCE for nitro and one for "Electric" i run box stock on both
and on one i run full rebound on the shocks and the other i run 1/2 rebound thats it?
now one of the cool parts about the trucks for the AE ones is the little changes will make big differences, so be sure to "Try" stock set up first! then if there is a "Need"
just do one small change at a time, Associated really did there "HomeWork" on this line of cars, oddly enough you come to find is that you wont find too many set up sheets??
because there is not really too many you'll need? the truck is pretty "Neutral" and good to go out of the box
the only downside? probally be the drooling you'll be doing while driving! cause you'll be having a grip of fun
1BLADE1 is offline
Old 07-22-2010, 01:19 AM
  #281
1BLADE1's Avatar
for the RC8T
if so the stock set up is pretty good, usually seems "Tires" are the biggest change factor.
but on average the 7,7,7 is a good place to start for diffs
if the set up is pretty good
but there is just a tiny bit more steering your looking for
say for example just give it a hair more toe out
or if the set up is great but need just a hair more rear traction
then lower the rear cambe link "One" hole at a time
shock oils, well there is a tough one? will depend allot on the track?
is there allot of smaller bumps or mogols etc.?
is it hard packed,but little bit of loose dirt on top,but basicaly "Smooth" with more open throttle sweepers?
and "Flowing Jumps"
or is the track rutty (or more like Holes in ground) with sharp ends in the ruts?
now the cool part you already have 2 kinds of shocks on the cars already!
run the stock oil as recommended,but first try the Non-Rebound set up where you bleed out the shock for no "Air" fill shock then push up the piston almost to top then slowly screw on cap this is non-rebound
run car,
then remove shocks, slightly refill them, but do not push up the piston,fill the cap "Almost" to top then put cap on and "Slowly" twist on cap allowing the air to escape this is "Full Rebound" and the car/truck will have a compleat different feel, but more common seems for a good majority of tracks "On Average"
will be the 1.1 x 10 pistons on 30 wt.
or the 1.3 x 6 on 35 wt.
1BLADE1 is offline
Old 07-22-2010, 02:47 AM
  #282
anybody running 18/54?
over geared?
Old 08-03-2010, 07:30 AM
  #283
DaveW's Avatar
I finally found a gently used RC8Te for sale! Im so siked! It just has a bent front dogbone and some chassis scratches. Anyone have a place they shop for parts that is usually in stock? Tower Hobbies is your 'backorder' source...
DaveW is offline
Old 08-12-2010, 01:52 AM
  #284
JBRacing47's Avatar
I've used amainhobbies with pretty fast turn around.
over geared?
I think so what motor are you running? What kind of temps are you getting?
JBRacing47 is offline
Old 08-12-2010, 08:07 AM
  #285
DaveW's Avatar
Losi Parts Warehouse seems to stock quite a bit as well. I just placed an order with them. I got sticker shock when i looked at tire prices for this thing.
DaveW is offline
