Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread
#6436
Hi guys, we've just published a build guide for the gearboxes on the DESC410R short course and DEX410 buggy. Take a look:
http://www.team-durango.com/blog/?p=2584
#6437
Holy smokes! Talk about timing. I'm sitting here looking at my broken down diffs. I recently purchased a lightly used 410r and found a chinked gear. Thanks for the info Team Durango.
Just checked out the build guide. Very well done durango. And thanks again. Good to have a clear understanding of what was wrong.
#6442
I put this sterring plate on my "R" version but my setup does not make use of the extra holes. It is a better quality piece but is not a "must have." I bought because I was trying everything under the sun to correct my steering servo issue before Tresrey released the aluminum version.
#6445
thanks
Rob
#6446
It hasn't been an issue with the tie rod though. I just refuse to pay $90 for the sidebraces.
Yes, I'm running at IR-CR.
I was thinking about my diff hoop and the ring/pinion thing. I've got a pretty bad high spot on my rear ring that may be causing the case to flex, possibly. I've got new rings to throw on, I'm going to do that before April Fools.
I tried drilling out my pistons and found that with stiffer oil I'm not sure if it's any faster. The car seems like it has more traction but it's a bit harder to drive. My lap tims are very simmilar.
#6447
I'm positive they're not cracked. The amount of flex between the motor and saver in the chassis is pretty extreme. I can bend it over my knee enough to pop the shaft in and out.
Team Durango 410 Gearbox Build Guide
#6449
Just finished building my R. I noticed that the towers have 2 extra holes for the shocks. Based on grapejuice's setup using the middle holes front and rear, do I use the innermost second hole or 3rd hole which places it right at the middle of the 5 holes?
Do you use the rubber stoppers for the shocks,especially if you have the boots?
And after trying to adjust camber and toe using a turnbuckle wrench, the ballcups would immediately pop out. Is this normal or are these junk and just find a more suitable alternative?
#6450
It's best to grease the rods and run them in/out of each ballcup when assembling to ensure they are free and stop them popping off whilst adjusting.
