Like Tree22Likes
Old 01-26-2011, 07:34 PM
  #5686
Konich's Avatar
Anyone think the TSR shock products are worth a try?
http://cgi.ebay.com/TSR-Team-Durango...item27b839e44a
Konich is offline
Old 01-26-2011, 07:36 PM
  #5687
rfleck's Avatar
Trader Rating: 58 (100%+)
Default lrp speedos are good
Even the older tc spec ans sxx comp are good speedos. I currently run the Sxx comp with a 6.5 and it comes off around 110F. They are perfect for mod. in a stock class, another story. You need boost to compete in stock classes.
rfleck is offline
Old 01-26-2011, 08:30 PM
  #5688
Jason Pelletier's Avatar
Trader Rating: 33 (100%+)
Premier hobbies came through with these parts for me. Great customer service well worth the wait. Anywayz heres a pic.... the servo horn very similar to the stock one. looks nice too.
Jason Pelletier is offline
Old 01-26-2011, 09:04 PM
  #5689
RCZILLA's Avatar
The v2 has boost though doesnt it, just not the older ones?
See LRP got a bridge kit now for updating software.
http://forums.radiocontrolzone.com/s...d.php?t=261928
RCZILLA is offline
Old 01-26-2011, 09:27 PM
  #5690
Glad you are happy! Anything else you need let us know!
We do have a few more RCE9801's available!
PremiereHobbies is offline
Old 01-26-2011, 09:41 PM
  #5691
hacker's Avatar
Trader Rating: 141 (100%+)
the v2 has got nothing on tekins 212, hobbywings 508, and other speed controls with stock spec firmware.
the stock spec v2 however is soon to be released and that be 'nearly' as good as the others.
hacker is offline
Old 01-26-2011, 10:18 PM
  #5692
RCZILLA's Avatar
What's difference with the stock spec comparied to the TC? Going by their site the TC has dual ADPC max Software (independent adjustment of Feel and Boost) I haven't ran a LRP ESC since they bought out the A.I stuff.
RCZILLA is offline
Old 01-26-2011, 10:52 PM
  #5693
tonyv2382's Avatar
Trader Rating: 67 (100%+)
Dude...ull be more than happy with the LRP.
Basically compared to the stock ull have more "feel" profiles and lots of boost to pick from or not pick from a well as drag brake. Its all youll ever need, just set it and the esc sorts everything out for you effortlessly.
tonyv2382 is offline
Old 01-27-2011, 06:19 AM
  #5694
rangerjkb's Avatar
Trader Rating: 45 (100%+)
Absolutely love using this shock technique in my Losi 8th scale, but I don't think this will work on the current Durango shock caps. Those do appear to be the same and would need to confirm they are concave within the upper cap head for the foam to fit and provide correct design function. Don't know if there is an additional hole within the shock cap to vent diaphram compression, but I guess you could remove the original oil bleed screw. Anyone using these?
rangerjkb is offline
Old 01-27-2011, 06:49 AM
  #5695
rfleck's Avatar
No, a couple of us did a similar experiment with other bladders. Maybe worth a shot.
rfleck is offline
Old 01-27-2011, 10:58 AM
  #5696
rangerjkb's Avatar
RCZILLA
If using LRP SXX or SXX TC Spec to run Modified motor, you'll like it (main differences are motor limits). Very smooth and provides great control/feel/ minimal timming adjustments for fine tuning. For stock motor timming applications, you'll be at a disadvantage to several of the other ESC manufacturers that captitalize on their abilitites to adjust timing advancement. The SXX & TC spec V2's are designed for Modified motors, not stock motors. They do make a Stock Spec that has advance timing profiles to choose from and would be much better for stock racing if wanting to use LRP.
Old 01-27-2011, 11:00 AM
  #5697
rangerjkb's Avatar
Nice pics of the parts! Awaiting arrival of my servo saver arm from Premiere Hobbies, today for install, can't wait...better peace of mind!
Old 01-27-2011, 12:43 PM
  #5698
RCZILLA's Avatar
RCZILLA
Thanks for your input. Im considering running the Trinity D3 6.5T Mod motor. Havent fully decided yet.
RCZILLA is offline
Old 01-27-2011, 01:10 PM
  #5699
grapejuice's Avatar
Trader Rating: 153 (100%+)
Hmmm, interesting: http://www.oople.com/forums/showthread.php?t=61920
grapejuice is offline
Old 01-27-2011, 01:31 PM
  #5700
Drift_Buggy's Avatar
Trader Rating: 22 (100%+)
Originally Posted by grapejuice
Yes, the 410 Ultra does look nice
Drift_Buggy is offline
