Like Tree22Likes
Old 04-06-2011, 05:07 PM
  #6586
rcjunky10's Avatar
Trader Rating: 227 (100%+)
Default Elite RC motor mount!
Guys, I just got off the phone with Brandon from Elite RC and he has a kit in hand and will start work on the motor mount. He said he should know by this weekend what the mount will look like.
I'll post an update after I speak with him!
rcjunky10 is offline
Old 04-06-2011, 07:19 PM
  #6587
BOLISARIO's Avatar
Trader Rating: 57 (100%+)
I thought he needed a certain amount of people to commit to buy before considering designing a mount? If not, then is he also designing one for the SC too? I would definitely buy both.
BOLISARIO is offline
Old 04-06-2011, 07:33 PM
  #6588
per4m28's Avatar
Trader Rating: 58 (100%+)
Please keep us informed!!
per4m28 is offline
Old 04-07-2011, 03:05 AM
  #6589
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
What's wrong with the stock mount?
Bman's 3XNT is offline
Old 04-07-2011, 05:51 AM
  #6590
rcjunky10's Avatar
The demand is there my friend Folks have been clamoring for an aftermarket mount for some time but with little focus on the 1/10th 4wd/SC space by the designers no such item was available. That will be changing shortly!
Will do! He emailed me last night with a few questions regarding the DEX and the DESC so I will keep you folks updated on progress. These mounts will be on par with his designs, and we all know how nice those are
Wrong, nothing! If you have ever used an ERC mount you'll know what I'm referring to. His designs offer a clean, quick, mechanically sound alternative to the stock mount. With an ERC mount servicing your motor becomes markedly quicker and provides for a consistent mounting process every time, with very low instance or likelihood of the motor shifting during operation when properly installed. The ERC mount incorporates the front portion of the center diff mount, similar to the stock mount, with single piece CNC construction, and a mounting block secured to the endbell of the motor, with your choice of either M3 or M4 bolt patterns. Installing/uninstalling your motor(s) literally takes seconds and offers precise positioning every time.
Keep an eye out for it my friend, I am convinced you will be thoroughly impressed
Old 04-07-2011, 06:01 AM
  #6591
Carlos69's Avatar
Somehow your post made me think of this
+ YouTube Video
Keen to hear how these turn out tho...
Carl
Carlos69 is offline
Old 04-07-2011, 06:33 AM
  #6592
R-E-A-P-E-R-'s Avatar
I've been down this road with Elite. He said he wanted 25 people to commit to buying one before he even started work on one.
I got the names of 12 people.
On another note there is a whole tread that popped up on here saying no one can get ahold of him. Most of his mounts are sold out and have been for months.
R-E-A-P-E-R- is offline
Old 04-09-2011, 09:07 AM
  #6593
teeforb's Avatar
Trader Rating: 94 (100%+)
are there two part options for the front and rear drive shafts for the 410? the manual says 310035 for front and 310036 for rear. And the parts looks different then what i see on my buggy. Please advise!
thx
teeforb is offline
Old 04-09-2011, 10:24 AM
  #6594
INFERN0's Avatar
I have one of those mounts in my 808 conversion. That thing is money!!!! Love it and will buy one in a heart beat for my DEX. I hope he makes one for the up coming DEX408
INFERN0 is offline
Old 04-09-2011, 06:54 PM
  #6595
SMcD's Avatar
Trader Rating: 61 (100%+)
Default Slipper Wobble
To the guys that posted about the slipper wobble issue - thanks. My new built DEX has this problem too. Thought it was just slightly warped spur at first, but you can see the center rear out drive and shaft wobbling now.
I am not alone. Wondered why my DESC410R with 550 and mod 1 gears was quieter... I emailed Team Durango and we will see.
SMcD is offline
Old 04-10-2011, 07:20 AM
  #6596
Wobble issue. Check all 4 of the screws that you mount the center slipper with. Loosen all of them. put the slipper in place with the clip "FULLY" inserted, and slowly tighten all 4 screws a little at a time in an x pattern, much like you tighten the diff screws. if that doesnt do it you might need to check the bottoms of the mounts to make sure they are perfectly square.
Dondor is offline
Old 04-10-2011, 08:27 AM
  #6597
Trader Rating: 49 (100%+)
thx
There is a lightweight shaft, option. If I remember correctly
aradaiel is offline
Old 04-10-2011, 01:29 PM
  #6598
HVAC25000's Avatar
Trader Rating: 19 (100%+)
Hey guys, is there a front one way for this car?
HVAC25000 is offline
Old 04-10-2011, 01:58 PM
  #6599
BOLISARIO's Avatar
Are you going to run it onroad?
You can probably lock the diff if you use the desc10r locked center.
Old 04-10-2011, 02:14 PM
  #6600
HVAC25000's Avatar
one way, not spool
