Like Tree22Likes
Old 03-11-2011, 07:01 AM
  #6451
BOLISARIO's Avatar
Trader Rating: 57 (100%+)
Originally Posted by TeamDurango
The rubber stoppers are only if you're not using boots
It's best to grease the rods and run them in/out of each ballcup when assembling to ensure they are free and stop them popping off whilst adjusting.
Thank you. So grease the rod ends, but what do you mean by," run them in/out of each ballcup?"
BOLISARIO is offline
Old 03-11-2011, 07:03 AM
  #6452
TeamDurango's Avatar
Originally Posted by xrider
I wonder if the big bores are the same shocks as used on the DESC410R? I found 3 different PN's on Losi parts house.
TDR230004 23mm stroke
TDR230025 29mm stroke
TDR230026 35mm stroke
TDR230004 23mm stroke (Standard front DESC410R) (front DEX410/R)
TDR230005 31mm stroke (rear DEX410/R)
TDR230025 29mm stroke (optional long-front DESC410R)
TDR230026 35mm stroke (Standard rear DESC410R)
You might be able to use the longer rear shocks from the DESC410R (35mm) on the rear of the 410 buggies but there might not be enough up-travel. Same with the 29mm SC front shocks on the rear of the 410 buggies, there might not be enough down-travel.
I hope the above 'chart' is explanatory enought though.
TeamDurango is offline
Old 03-11-2011, 07:04 AM
  #6453
Thread the turnbuckle fully in / out when you're assembling the turnbuckles - this just frees them up a little and allows you to adjust them without them wanting to fall off.
Old 03-11-2011, 07:05 AM
  #6454
dangerwr's Avatar
Grease 'em.
dangerwr is offline
Old 03-11-2011, 07:08 AM
  #6455
Originally Posted by dangerwr
Grease 'em.
Old 03-11-2011, 07:11 AM
  #6456
BOLISARIO's Avatar
Gotcha! Grease 'em then thread them in/out to loosen the plastic a bit to make them easier to adjust.
Old 03-11-2011, 07:21 AM
  #6457
EAT DIRT's Avatar
the diff building guide is a nice touch ...how about a guide on how to get the sun gear out of the diff Both front and rear diffs in my car have sun gears that are jammed in there
EAT DIRT is offline
Old 03-11-2011, 07:30 AM
  #6458
jland's Avatar
Trader Rating: 87 (100%+)
Yep, I had a ring gear go bad and trying to get the sun gear out it broke in 2. What I did on the new one was lightly file the outdrive where the gear sits and it comes off easy now.
jland is offline
Old 03-11-2011, 07:33 AM
  #6459
Surprisingly you can usually suspend the crown gear side or turn the moulded casing side upside down and the gears will fall off on their own over the course of a couple of hours or so.
If you have stubborn gears that won't fall off, you can try speed up the process with some WD40 or similar.
There are other things but it's better for us to write a guide than try to explain in a forum post.
Old 03-11-2011, 07:44 AM
  #6460
EAT DIRT's Avatar
Ya they are on there ,It's getting to the point were I'm going to cut the diff house to save the gears and outdrive
EAT DIRT is offline
Old 03-11-2011, 07:47 AM
  #6461
Have you tried the above?
Old 03-11-2011, 07:55 AM
  #6462
BOLISARIO's Avatar
One other build question: When installing the rear hubs to the arms, the manual says to file something on the arm or hub but I'm not sure which part it's pointing at. What am I supposed to file?
Old 03-11-2011, 08:00 AM
  #6463
You don't have to file anything - the arm was revised but the manual not changed.
Old 03-11-2011, 08:03 AM
  #6464
BOLISARIO's Avatar
Yeah everything felt smooth and was wondering what was missing. Thanks for the quick reply.
Old 03-11-2011, 08:05 AM
  #6465
dangerwr's Avatar
Yessir! A little bit of black grease makes 'em real nice. Funny thing is that I know to do this but always forget. Not sure what is wrong with me?
dangerwr is offline
