Like Tree22Likes
Old 03-11-2011, 08:54 AM
  #6466
Trader Rating: 17 (100%+)
Originally Posted by xrider
Search grapejuice setup and page down some. You'll find it
Used grapejuice's setup last night at the track and it ran extremely good compared to the first time I ran it. It handles great. Thanks for the help.
bobsavenger is offline
  #6467
EAT DIRT's Avatar
Originally Posted by TeamDurango
Have you tried the above?
I haven't tried the WD-40 yet.I'll try that first before I operate
EAT DIRT is offline
Old 03-11-2011, 03:52 PM
  #6468
SuperEk4's Avatar
Trader Rating: 32 (100%+)
Where u guys buy your durango? Do Towerhobbies sell?
SuperEk4 is offline
Old 03-11-2011, 03:56 PM
  #6469
Briguy's Avatar
Trader Rating: 125 (100%+)
Tower does not sell Durango . Losi Parts House and amain do sell them though . Or you can contact my LHS as they will ship out whatever you need .
The Bobby Co. 815-875-4433
Briguy is offline
Old 03-11-2011, 04:25 PM
  #6470
SuperEk4's Avatar
I think amain is selling 410r at usd325 after $25 discount? Cheapest?
SuperEk4 is offline
Old 03-11-2011, 05:20 PM
  #6471
Trader Rating: 75 (100%+)
should've kept it
gixxer420 is offline
Old 03-11-2011, 05:31 PM
  #6472
SuperEk4's Avatar
Originally Posted by gixxer420
should've kept it
Yeah but wat to do this is life
SuperEk4 is offline
Old 03-12-2011, 10:52 AM
  #6473
Just about done with the build finally.
Have to mount the electrics and paint a scrub body.
Question. How do you all tighten up the screws on the motor?
L-Wrench? Ball End Hex?
Thanks for any advice.
One other thing. Anyone have any experience with one of the large center spur bearings being tight? Non free spinning? Seems like this bearing is binding the center part of the entire drivetrain.
Dondor is offline
Old 03-12-2011, 11:03 AM
  #6474
TraxxasPeter's Avatar
Trader Rating: 21 (100%+)
Default durango for sale
http://www.rctech.net/forum/r-c-item...reat-deal.html
TraxxasPeter is offline
Old 03-12-2011, 11:38 AM
  #6475
BOLISARIO's Avatar
Trader Rating: 57 (100%+)
I used an L wrench. I wish Elite RC made a mount for the 410.
BOLISARIO is offline
Old 03-12-2011, 12:07 PM
  #6476
hlb14's Avatar
Trader Rating: 28 (100%+)
hlb14 is offline
Old 03-12-2011, 12:43 PM
  #6477
get cap head 3mm motor screws. and a 3mm ball end hex driver. its byfar the easiest way
Old 03-12-2011, 01:20 PM
  #6478
Trader Rating: 49 (100%+)
If you have a bad high spot you might find rebuilding following our new gearbox build guide fixes it. The high spot could either be down to shimming or an incorrectly installed crown gear - but it's likely fixable without buying any new parts.
Team Durango 410 Gearbox Build Guide
It's built correctly. There are chips on some of the teeth, because they're not updated ring gears... yet. I'll probably disassemble them tomorrow and take some pictures.
aradaiel is offline
Old 03-13-2011, 08:27 AM
  #6479
PS, I've got a venom 4500mah 50c saddle for sale. I just switched to a racers edge battery.
It works fine, I just wanted to try something different. $50 shipped
aradaiel is offline
Old 03-13-2011, 05:27 PM
  #6480
Bad news from the new build.
The front half of the slipper unit, the part on the front side, the larger piece with the machined threads was warped, never hit anything today at the racetrack and didn't notice it until it was a problem.
The machined part that is threaded is misaligned from machining causing the entire back half of the assembly where the tension nut and other drive cup goes to wobble severely. This caused the drive pin on the rear to basically wear in half after 6 minutes of runtime and loosened up the setscrew on the trans gear which eventually broke a tooth on the ring gear.
Going to contact distributor tomorrow.
Dondor is offline
