Tekin RX8 1/8 Scale Brushless ESC Thread
#1353
Hay Randy P.
I would like too by two tekin T's, but there is not any on the Tekin site.
I'm a big man , and need 4x, I will send the T's if you need, can you help.
Thanks Tim3.
Thanks Tim3.
#1355
I haven't tried it yet. But I have run Neu 1515's in my buggy on a number of occassions and can't imagine it would be significantly different. When I ran the my 1515 2.5d in my rc8 it actually ran hotter than the 1512 3d. The best I could figure out was that there wasn't enough load on the motor in the buggy given that the same motor runs ice cold in my 8t 2.0 truggy. In short, too much torque. I also found it made the buggy a wheelie machine if not careful. My T8 motor in the truggy can wheelie at will, so it may be too much in a buggy unless you soften the low end down a bit. Not sure how it will handle the lighter load either as far as heat is concerned.
#1356
Tech Legend
Thanks for the info. The 2200Kv Castle Neu I put in my Rc8 when the Neu 1512 2.5D/F let the magic smoke out definitely had a lot more torque. Good to know then that the Tekin is similar.
I'll probably take a wait and see approach for now. Hoping to see more buggy combos in stock.
#1357
#1358
But you'll pull more amps because of the higher gearing, so the gain wont be significant.
#1359
I'm running a 2250kv (so truggy) in a losi 8ight buggy on 5S...It flies and I have absolutely no heat problems. the gearing is 15/46.
#1360
Ok so i got my hotwire today and it's not working. I installed it and when i plug everything in it just says step 1 plug the esc in step 2 plug in to the computer. I do that and the green likght on the hotwire flashes rapidly and the rest of the red led's are on solid. so what am i doing wrong? It won't let me click on or open anything. My computer runs off vista........... Any help???
#1361
#1362
That's great i guess i'm going back to nitro. I don't understand what the problem is. They say we live in the modern era of technology so why write programs that don't work with modern programs. Way to go. I am so sick of wasting money on crap that i can't even use
#1364
Hey Pink Sleeve I dont run vista but here is a video Randy Pike made on Youtube showing how to run the hotwire on vista.
http://www.youtube.com/watch?v=tTp3tUL9u8Y
