Tekin RX8 1/8 Scale Brushless ESC Thread
I did a print screen....
It updates and shows this
Then a few seconds later this screen appears and then closes out hotwire
UPDATE: I just kept reupdating (11 times) and I have no idea why but now it finally updated without erroring out. I got the ESC to work and its back to normal...strange
Hotwire Software
Where do I get the Hotwire Software from?
The Tekin link is down....
LOL that interface looks so cool. Kinda Terminator like.
For you guys having intermittent issues with hotwire. Make sure the usb cable is snug to the hotwire interface. Even though it may light up red with power, it may not be fully seated. I wasted about an hour trying to troubleshoot it when I first got it (it wouldnt communicate with my RX8).
USB's especially on laptops are multiplexed in some fashion. I've found that if I have too many things "running" on my USB's on my netbook for example my success rate for software updates can be affected.
Not sure if this is your case in particular but something to consider.
It looks cool but is a usability fail, I like red esc much better but would take the programming software of the green type any day. #1 problem, not being able to slide bars or input the # I want instead of repeatedly tapping up or down arrows. #2 is the % of 30 on the timing, just give me a scale of 1-30, dont make it more complicated than it needs to be.
TY, The keyboard arrows is new info to me, thanks, I know I tried to slide the sliders and was unable to (until I try it again I'll mark it up to user error.) The timing info also helps as well.
Hi all,
I have a problem on my RX8, but it is quite interesting. The problem is; when I turn on the power switch on the ESC, the motor starts to turn at the highest rpm and then stops and works normal. But, while running my car, sometimes this situation occurs and I am loosing the control.
I have removed my servos, changed the receiver, changed the voltage protector, disabled the ESC's bec and feed the receiver through another battery, but problem still continued. At least, I have changed my rx8 with new one and problem solved. What can be the problem? Is there any one who had same or similar problem?
I am using RX8 with 1550kV truggy motor, 6S battery, spektrum sr3300t, spektrum voltage protector, savox 1256 for steering and savox 1258 for mechanical break on my losi 8T.
What size are the screws that hold on the fan? Thx
Hi all,
Has anyone ran the rx8 in a 12th scale with 1s lipo? i'm running a t bar and figure the extra weight will help balance the car while providing less on resistance than the rs. Just curious if anyone has tried it and had any problems.
Ryan
Ryan
The Rx8 will not operate on 1s.
why are these out of stock almost everywhere, is there still that huge of a demand for RX8's
