Tekin RX8 1/8 Scale Brushless ESC Thread
Randy, when I calibrate radio/esc, should my throttle/brake be set to max. (in the case of my radio 120 %) or just 100% ??
No, just do 100/100 for now.
I have not seen this.
A few things to look for. Swap the PT out with another. It's possible it's shorting inside, I just had one of my 8 year old ones do this to my E truggy.
If adding the cap helped the situation try this next. Remove the sensor wire from the esc side and see if this corrects the issue.
Are you running a single servo or duals?
I am running a single servo in an MBX6 Eco buggy. Running the Airtronics SSR Rx and Servo 94951.
I did try swapping the transponder with the one in my other buggy and it did the exact same thing.
I eventually did solve this problem by buying one of the newer AMB transponders. The old ones have a minimum voltage of 4v according to the specs, and then newer RC4 style transponders are good down to 2.4v
I put the newer style transponder in and havent missed a lap since. The other one is working perfectly in my SC so I dont think it is a transponder issue. Just seems that the servo draws a touch to much current from the BEC when changing directions and the voltage drops momentarily. It just seems weird that it doesn't brown out if I run the servo all the way to the lock and push the servo to draw power. It only does it for a split second when changing directions.
Is it ok to come off the receiver with a Y harness and connect it to the RX8? That way you don't have to unplug it from the receiver or take the battery box apart every time you want to program it.
No, you can't use a y-harness because you are supplying the receiver with power at the same time. I use an extension that comes out of the receiver box so that I don't have to plug it in and out of the receiver each time.
No problems.
PS, for anyone getting into this hobby you can't go past the quick support that Randy gives on here, I think I speak for most on here that not only is the tekin product second to none but so is there customer service and setup support, it makes setup easy when you can get help easily...
Once again thanks Randy and keep up the good work.
Cheers Justin aka dumbass
Ha! No worries, we've all been in a rush to play with our toys! lol.
Posted this in another thread, but thought i'd throw it up here too since i'll be getting an RX8 for it.
I just got a cheeeeap Serpent 960 on-road 1/8 with a lecky conversion kit. I have no electrics yet, and am just reading all I can so I don't waste money on electronic paper-weights.
The conversion comes with a layout for 4 x 1S batteries. Now, i'd rather do a 5S or 6S set-up, but it will require hacking the chassis and I like the idea of keeping it all nice and tidy
Would a 4S 2200kV set-up get particularly hot on a large medium traction track? I'm not worried about insane top speed, just want something fairly quick and driveable.
It will really depend on the weight of this setup. I've yet to see one run on just 4s. I'd suggest a 4s 2050 or even 1900 setup that was geared properly.
The 2250 setup is a truggy motor so make sure it fits.
Hey randy, or anyone knows the awnser to my question.
I just got my rx8 2050 combo, and im running it on 4s. I noticed the esc was getting too hot for my likings. 145 after a 6 min qualifier. So I decided to put the fan on the esc, and it turns on when I first turn the esc on, but then it shuts off immediatly after. Does the fan just turn on when the esc needs it, or do I need to change something within the hotwire? If you need any more info about my set-up just ask and I will feel free to post it if need be.
R/C Tech Elite Member
The fan runs for a few seconds when you first turn the power on to show you the fan is working...
It then shuts off till the speed control gets hot enough to need the fan.
140 isn't hot and I would not run a fan unless I see 6 or 7 led's on the onboard temp indicator after a run. Which by the way will likely not happen if your setup/gearing is correct.
