Tekin RX8 1/8 Scale Brushless ESC Thread
#8731
No advantage to running 10awg wire. If you were to see the conncections insde the Lipo battery you'd understand why it's a waste.
Run 12awg wire, you'll be fine.
#8732
rx8
I just got my rx 8 and it ran great for. The first heat but now it just shuts off after about four minutes . My other buddy is having the same problem do I need to send it in . Please help.
#8733
#8734
Also does the RX8 output 6 volts or 7.4 for servos..
#8735
I wanted to give a big thank you to Tekin's service department. I sent in 3
rx8's and 4 motors and they really did me right on the warranty and service. Thank you.
#8737
The question was prompted because my RX8/1900 combe didn't have the batt wires...
#8738
On my GTP, I use 10 AWG for the power and 12 AWG for the motors. I use the EC5 connectors for power and 6mm or 6.5mm for motors.
I solder up my own A123 batts with battery bars. The original thin spot welded tabs will blow off the cell with the burst Ampdraw that I pull with some of my setups. I've blown the copper traces off my AcePow batteries with the RX8. The RX8 is still my ESC of choice for 1/8 dragracing. With 4s2p A123 on the RX8, I'm just as fast with peeps running the MMM on 6S!
btw I do use 3 additional caps and tvs's on my RX8.
#8739
#8740
We're going to need more info than it just "doesn't work". What battery are you using, connectors, etc.
Are there any led's displayed when this occurs? Do you have steering? What motor are you using? etc.
#8741
because that is the way my RS is working.... Although I am leary
of trying it on my RX8.
Thanks guys for the info.....and tip. Great product's no matter what
the hater's say!!!!!!!!!
On a side note...the 2050 buggy motor on 3s, in a Slash 4wd. Any idea's
on a good starting point for gearing?
#8742
It temps at 140 the fan works I am using two thunder power 5400 it ran great the first heat but now just shuts off the steering still works and if it sits for a minuteit will start working .my buddy sent his in at got the newer version and his was doing the same thing.
#8743
Sorry the motor is a tekin 2050 and their is no lights that light up when this happens.
#8745
Hey Randy, my rx8/1900 has been working great. I've been getting a radio glitch at one certain section on the track after braking hard for a 180 following a staight away. I"m using a FM radio and it only happens at that one spot. Any ideas?
