Tekin RX8 1/8 Scale Brushless ESC Thread
#7606
i have a problem with my new backup RX8 - strange that it is still the black ESC but as long as it works i dont care.
however it does not work well with hotwire
first it took like 20 attempts to update to ESC to the latest software and now it is not possible to apply any settings to ESC as I keep getting message to get the latest version of hotwire from tekin website. I HAVE THE LATEST version. I even downloaded it again and installed on my second laptop. same problem.
ESC went right from the box to hotwire as I first wanted to have it setup before soldering
#7607
Had a race in canada, ran 3 quals (5 min) and the main (10min) and i had no problems. I mounted it with servo tape wires were pretty long and loose as well with the sensor wire. I ran a Venom 4S 5000 mah 35C lipo. The vehicle i was using was the Kyosho inferno VE. I do have a few questions:
-two fins broke off my esc fan, where can i get a new fan?
-also, when i was running my VE the esc and motor got really hot (150 for the
motor and 155 for the esc) is there any gearing recommendations for the VE?
-Would timing make a difference in temps?
Three other people ran there Tekin's w/o problems.
Thanks.
P.S i also ran a qual (5 mins) and an main (10 min) at an indoor track
Thanks.
#7608
Team Tekin
Thanks.
Thanks.
150 motor and 155 esc are nothing to be concerned about. When it gets to 170, then you need to start to re-evaluate your setup.
#7609
Also, don't use a temp gun on the esc when worrying about temps. Watch the leds when you are at neutral and they flash every so often ranging from the lone led on the left (cold) to all 7 leds (about to thermal). If you see anything less than 6 leds you're a cool cucumber.
#7610
Okay, I just got off the phone with Tekin about my broken t8. So basically, since it's the original model, I have to pay a min of 25 and what ever else it cost to fix the motor. Out of all the issues I have had, now I am out of pocket. This sucks! The shaft just spins in the motor! This is not cool!
#7612
#7613
#7614
Thanks.
Thanks.
Glad it worked good for you this weekend!
#7615
here is a screenshot of the error I get
what can be wrong. i have the latest version from the web
#7616
Instead of sending it in, can i fix it with Permatex 64040? Or can you guys just send me a new rotor and i'll send u my old rotor at the same time? Im trying to reduce my down time... i really would like to race this weekend...
#7617
it's a v2 rotor. i remember sending it in with some other rx8 that had issues and you guys replaced it with a v2 rotor...
thx
#7618
Well, I have been informed, by my LHS and track owner, that Tekin is going to work with him to see that him and all of his customers are taken care of in an unheard of, timely manner. It also sounds like we may be doing some local R&D for them too. Kinda cool, imo. Hats off to Tekin for that.
Guys, trust me, as bummed as I may be about all of this, I am not pissed by any means. I plan to continue to run the RX8 in my buggy for a long time to come, without a second thought. Was just questioning the return process, really.
#7620
Ty's right, we'll have to find out who you talked to. Ty's the service manager so whatever he says goes, period.
The kyosho is a 3.4ish internal diff car. What's your gearing? The guys are right though, your temps are more than fine.
Part # on the fans is TT3812
