Tekin RX8 1/8 Scale Brushless ESC Thread
#7546
Well, come to find out, my theory was correct. Not only did I crash one RX8 but two in the past week. The second didn't even make it through one race without issues. I had originally thought that it was just my receiver (all the leds
were flashing) but now I have 1-3-5 led's flashing on both and intermittent operation. Pretty bad that mine, and one of my racing buddies' RX8's died at
almost the exact same time, at the exact same spot on the track tonight, during Wednesday night race league at our local indoor track. That's 3 RX8's down total. I'm so bummed, really. This is the only car that I have to run, right now, and I have the first race of our outdoor/summer long state series next Saturday with no esc to run. E-Mailed in for my RA# just now. Sure would be nice to not be a race down right at the start of the season.
#7548
My return email, for my RA# request, states that it will be 2-3 DAYS before
I even GET a response. REALLY?!? Good Lord this is not a good process. The
even bigger problem is after spending $600 in esc/motor combos to hopefully
not be in this mess (without a car to run my series racing), here I am trying to
find more $$$$ to buy something USED just so I can race!! Please tell me this
isn't true Tekin, please.
#7551
quick question,
when posting off this ESC for RMA, do i need to send the box too? itll be more bulky and expensive if i have to
#7552
#7553
Posting on here will not get you an RA# any quicker. If you're looking for a faster response you can always call us.
#7554
MY TEKIN RX8 UPDATE....
So after reading this for 6 months and finally getting to race my buggy alot etc i thought i'd give a quick update on my RX-8 Situation.
background cliffs
1700/4s too slow
had a problem, ended up being the receiver
2050/4s
GREAT but wanted more run time
1400/6s
had an ESC failure randy took care of me ASAP.
Overall LOVED this setup.
1700/5s
Moved to LA Ran my car 3-4 times a week had a couple failures but there was a guy with a couple spare boards helping me out.
Thought i had a board failure.. it was another RX..
NOW since I have gotten that board in later february I have ran the car a dozen times with no problem. INCLUDING a tug of war local fundraiser I placed second in. And a brutal chassis slapping long jump.
I just built on offroad track that is getting ready to open for summer racing so my buggy and my RX8 will see TONS of track time since its 200 yrds from where i live =)
Overall the newest board in my RX8 has been bulletproof compared to the last few. The 1700/5s is a plenty of power and provides a really smooth feel with good punch and top end when needed since it has a few more rpm up top.
So we are going on month 3 with no ESC failures. Right now I am SUPER happy and hope to continue my relationship with using tekin products.
Chase
background cliffs
1700/4s too slow
2050/4s
1400/6s
1700/5s
Chase
#7555
intermittent throttle and no throttle
RX8 working beautifully until yesterday. Had intermittent throttle and at times no throttle with steering. At times the ESC would just turn off as well. Thought it was a failing switch, so I cut the switch off and hard wired. Problems still persisted. Thought it was the battery connectors, so I put on a battery with plugs known to work. This seemed to solve the ESC turning off, but still had the intermittent throttle and at times no throttle with steering.
I've read that absolutely no throttle with steering is probably a board failure. Is this the issue I am having?
Thanks for any help or input.
#7556
if you use a extension for the hotwire make sure that connection is good still too...
#7557
Team Tekin
#7558
#7559
Guys, I am still having trouble with my 2050 running hot in my Losi 8 buggy. I had the board failure on my ESC a couple months ago. Prior to that the motor was a rocket and always came off at 130* (it was pretty cool outside then though)
Tekin fixed my faulty circuit board, but since then the motor runs hot and doesn't seem to have the same freakishly fast power it once had. It still goes ok and is fairly fast, but it isn't the same as it was. I have tried gearing everywhere from 13/45 up to 16/45. Still came off hot with all gearings. I use my brakes but not excessively so and no more than before. I've tried a different brand of ESC with the same results. So, my questions are:
1. Can the ESC failure cause permanent damage to the motor?
2. Is 180* to 190* really too hot after a 12 minute main?
#7560
R/C Tech Elite Member
