Tekin RX8 1/8 Scale Brushless ESC Thread
#6962
What would you tekin guys recommend for a Ve8 that will be driven on both a large loamy track (might be clay soon) and a smaller high bite track? I was thinking of either the 1900 or 2050. Will be run on 4s and may be running mains with the nitros. Links to tracks...
http://www.youtube.com/watch?v=a04tKHX7kTU
http://www.youtube.com/watch?v=AgS0l_qEQDY
#6963
Team Tekin
#6964
Finally I got my RX8/1900 system from Tower Just opened the box but it seems that it did not come with any double-sided tape even though the manual says it should be included... Got me a little worried. What parts should I get in the box? Besides the ESC and motor, I got a fan + screws, 3 cables and a sensor cable + holder.
#6965
Team Tekin
#6966
just took my 2650 3s 5000mah combo out for a test spin in my hyper 9 and it is pretty damn amazing. wheelies when the tires get lots of grip! the car feels pretty lightweight (which was the intention, w/ a high Kv 3s setup) and is sooo smooth!
ran it for roughly 10-12 minutes and still had 3.6 volts per cell left. and it was running very cool, 120-140 max afterward w/ the esc much less.
i am very pleased with the potential this setup has on a tighter clay track. vs heavier 4s setups like my MMM 2200 rc8, which feels a bit barge like after this!
edit: timing was min...i cant imagine ever needing more than the lowest setting
#6967
#6969
#6971
#6973
If you're quick, Hobby City has some of the new 5800's still in stock. Only problem is it's only the 25c that's in stock, 30c version is still out.
#6974
tekin rx8 secure setup (Combo Tekin rx8 motor T8 trugghy)
Take a Watt meter,
simply do not have to exceed these values:
1500 watts peak
100 amp peak
160 ° F max
following these values will not break anything
1500 watts peak
100 amp peak
160 ° F max
#6975
