Like Tree495Likes
JConcepts Thread
Old 06-24-2024 | 05:16 AM
  #10576
AHR43's Avatar
Default Tactic wheel
Recently purchased a pair of Tactic - Slash/Bandit, Street Eliminator 2.2" 12mm hex FR wheel - Chrome. No. 3399C.
Noticed the bead area has what appears a rubber insert. What is that all about? Standard gluing procedure still work? Mounting a pair of Pro-Line Hole Shot buggy fronts using JConcepts Advanced Formula Medium Vis. CA and JConcepts medium application tips.
Use will be on my backyard grass track oval - TRX Bandit Buggy. Thanks. -AC
AHR43 is offline
Old 06-26-2024 | 06:23 AM
  #10577
PW's Avatar
PW
Originally Posted by GOING FAST
I just bought a set of the smoothies 2 in silver compound and was wondering what tire sauce works best for these tires. The track is a high bite clay surface
It varies depending on the track/dirt, so I recommend asking the local fast guys what they are using. The popular ones are FDJ Silver, SXT Baja, and TDK Gen2 or Edge.
Do you make a radio bag for M-17 radio’s? Thanks, Dave.
Yes, unfortunately they sold out quickly and no ETA.
​​​​​​​Recently purchased a pair of Tactic - Slash/Bandit, Street Eliminator 2.2" 12mm hex FR wheel - Chrome. No. 3399C.
There shouldn't be any rubber insert in the bead, it should just be the natural black plastic minus the chrome coating. If there is a rubber insert in the bead, then remove it and glue as normal.
AHR43 likes this.
PW is offline
Old 06-26-2024 | 06:48 AM
  #10578
looks like they’re all backordered right now, but I have one and it’s a fantastic bag. I’d recommend grabbing one once they’re available
Cinnabun is offline
Old 06-26-2024 | 07:05 AM
  #10579
AHR43's Avatar
Thanks, Paul. Used a knife edge trying to get under the band and lift it out. Acts like it is bonded to the wheel. Decided not to muck about with it and left them in place. Tire still seats fully in the bead so will glue tires with the band in place.
Yeah, understand now why the band is there. No harm, no foul. Actually been doing a similar thing myself by wrapping rubber bands in the wheel bead area when spray painting other wheels. Only difference, they unwrap and come off readily. Again, thanks for the reply and info. Best regards. -AC
AHR43 is offline
Old 07-10-2024 | 08:06 AM
  #10580
Cain's Avatar
Tech Legend
Paul, any plans to offer those 1/8 Turf tires premounted? These are definitely more of a challenge to glue so be cool to just have those ready to go out of the box premounted.
Also any ideas on when those 4wd front sirens will be available to buy?
Cain is offline
Old 07-10-2024 | 08:30 AM
  #10581
PW's Avatar
PW
No plans at this time....1/8th turf racing is just way to small, especially in the USA.
I don't have an ETA on the 4wd front Sirens, but they are on order .
Cain likes this.
PW is offline
Old 07-18-2024 | 05:53 AM
  #10582
PW's Avatar
PW
Now available along with some fresh turf Stadium Truck tires Click Here
Cain and MrLean like this.
PW is offline
Old 07-18-2024 | 08:43 AM
  #10583
Cain's Avatar
Tech Legend
Awesome! If you guys are able to try out those turf stadium truck tires in a dirt compound like green, be very curious on that as well as in the old days of nitro 2wd truck the losi step pin pattern in red compound was perfect for alot of the tracks that did 1/8 nitro on them as well. could see a benefit to having something like that again over the goosebumps.
BRabbit likes this.
Cain is offline
Old 07-23-2024 | 09:50 AM
  #10584
Cain's Avatar
Tech Legend
So for these three tire types:
- Dirt Bite
- Recon
- Falcon
Assuming same compound, what conditions would you use each type in over the other one? Will there be premounts of any of these in the future?
Cain is offline
Old 07-23-2024 | 02:51 PM
  #10585
Any thoughts or development around releasing a fuzzbite with reinforced sidewalls? It feels like everyone is gluing their sidewalls these days, and I for one would pay a premium to have a tire where it wasn't necessary.
Cain and shortcut3d like this.
Griffin is offline
Old 07-29-2024 | 01:11 PM
  #10586
Cain's Avatar
Tech Legend
Got to use the new Siren 4wds for our Midwest Turf Championships .
During testing tried them out without any sidewall gluing and they felt very similar to a set of Schumacher mini darts that had the same amount of rows trimmed, but a bit more consistent based on the more flat profile and pin count I think is more.
I glued the sidewall which those "bars" on the side seem to act as nice stops for the glue. Vehicle was money at that point, used SIrens front and rear for 4wd, Drop steps for rear 2wd buggy, and then the Nessi and swagger 1/8 combo to take the win in all my classes. Great work on the tires!
PW likes this.
Cain is offline
Old 08-05-2024 | 12:41 PM
  #10587
Ordered the new Swaggo 2wd slim front. Planning on running them on turf with Siren rears. Benefits over fuzzbite and original swaggers?
shortcut3d is offline
Old 08-06-2024 | 05:40 AM
  #10588
PW's Avatar
PW
Special things are in the works
- Dirt Bite
- Recon
- Falcon
Dirt Bite would be similar to Reflex; med or hard packed with some loose stuff on top. Premounts coming
Recon would be more natural dirt with loose, rough conditions. No
Falcon would be similar to Reflex and Dirt Bite, but even more loose conditions. Premounts coming
I don't have any experience with them, so just something you have to try. I'm thinking they should have a little more steering over a Swagger, but slightly less than the pin fronts.
Cain likes this.
PW is offline
Old 08-07-2024 | 10:16 AM
  #10589
We tried the Swagoo last night and they are exactly as PW described. Should be a good tire for a high grip carpet track where you want smoother steering than a pin tire offers.
Seems that they have a lower profile sidewall than I remember the Swaggers having?
MrLean is offline
Old 08-07-2024 | 10:29 AM
  #10590
PW's Avatar
PW
Yes, the Swagoo is based on the Fuzz Bite/Pin Swag carcass instead of the Swagger carcass.
PW is offline
