JConcepts Thread
#5568
Bro codes
Do you see the bro codes as a upgraded V1 bar code or just another tuning option? Think they are going to be a more versital tire then the v1 bar code?
#5570
The Bro (broken in) Codes are used for indoor clay tracks where a broken in tire is prefered. It is just a tuning option when a tire like that is faster. V1's are still a good choice for indoor or outdoor.
#5571
Many tracks are faster when the tire is broken in. This is why you see lap times getting faster as the tires wear down. JConcepts took that concept and made the Bar Code already broken down. I personally saw the results of this last weekend.
#5573
#5574
when can we purchase TLR 22 wing mounts?
#5575
#5576
Will there be any response from Jconcepts to the Team Durango DEX210 +8mm DIMEC chassis?
#5577
#5578
The team drivers also run custom Alloy extended chassis utilizing the stock plastic pods, not economically available to some. The Plastic +8mm chassis has a bump on the side towards the nose and is also wider....
#5579
I would also note on your website that your DEX210 Finnisher wil NOT fit the RTR DEX210, as it uses the new +8mm plastic chassis.
#5580
