JConcepts Thread
#5551
Actually came in today
The TLR22 wing is about a half of a hole different; basically use the 0123 wing and then move the hole out a half-hole on each side.
Shouldn't be to much longer and you won't have to do that
Paul, have you guys gotten a chance to look at the wing mounts for the RB6 and see if just maybe the Associated wing mounts you guys make will fit?
I apologize if it has been asked before and I will accept my rightfully deserved harassment.
#5552
I just got some bar codes for stadium truck. Question is do i mount the big Y or little y out? Or what is the handling difference both ways? Thx
#5554
For what its worth-I have always went with the understanding that with the big Y outside the tire will yield more side bite than with the small Y out...I always run small Y out in the front, and large Y out in the rear on my truck-takes the twitchiness out of the steering...
#5555
#5556
just want to say i love the new 2012 Ford F-250 Super Duty XLT SuperCab body! I'll definitly be getting one for my truck! Thanks!
#5558
hideeho
Is there an ongoing problem w/ green DD's being cast improperly? Out of the last 6 pairs of DD's I have ordered from A-Main 2 pairs have seemingly been cast improperly (they were ordered 6-8 weeks apart). One side seems to be cast with a thinner carcas on one side. The pins look to be the same height all the way around, but the body of the tire seems thinner. The 1st set I got I didnt even realize the problem until they were mounted & I found they were very out of balance. I didn't realize the source of the problem @ the time. The 2nd set I felt the problem before mounting it but didnt really think anything about it, so I mounted them on up. Those were out of balance exactly like the 1st set. once I wore out the 1st set I cut them off wheels & found they had the same thin spot feel (this was with virtually no pins left on them). I am going to be ordering another set from A-Main this week. If they have the same problem can I return them to JConcepts for exchange?
Has any thought been given to releasing Rulux B4.1 wheels with hex drives? I really like the Rulux wheels, but I can see the writing on the wall that everything is going hexes for buggies. Currently, I do not know of ANY wheel being made for hex drive buggies that is not a dish style. This would seem like a great oppertunity to fill a niche that doesn't have any other competition. Also some black Rulux wheels for the buggy would REALLY nice. Or, am I the only one left buying the last of the Rulux stock?
#5559
Ran the new pressure point st truck tires today. Indoor track once it dried out a little they worked great!!!
#5560
I think I have asked this but will there be an rt5 finisher any time soon
#5561
hideeho
No Rulux/hex wheels at the moment.
#5562
Please contact us directly about the DD issue - [email protected]
Thanks for the quick answer.
The tires I have with the issue are well beyond the point I would ask you to do anything about it. I will be ordering some more on the 1st, if I have the same problem with them I'll shoot you an email, thanks.
