Team Associated B6.4 and B6.4d
#691
While lowering the CofG will help you don't often read of people experiencing traction rolling with modern cars so I would suggest it's a setup issue. Have a look at the carpet setup as it is probably generating too much traction, lengthening the top links, harder springs and thicker oil will help.
As mentioned, the extra weight is about getting the front to grip and rear to rotate.
Good luck
Good luck
#692
I do. To my knowledge, the B6.4 with the kit setup (minus sway bars and a 7k 2 gear diff) is the way to go. I'll be getting one this week to replace my B6.2. For that track, schumacher mezzo rear tires and low profile cut staggers are the tires of choice. A Hobbywing justock esc is good enough for getting started and running for a while. 29 tooth pinion and 72 tooth spur is the standard there. If your just coming back, then most 17.5 motors will be good enough to get you into the groove. Radio Control Hobbies and Raceway (RCHR) has everything mentioned above and everything else for you to get up and running. They race 17.5 buggy on Wednesdays at 7PM and Saturdays at 5PM.
#694
Any new carpet setups or new things to try? I have been running the Brent Theilke setup from the JConcepts race for a while bu think i could use some tuning.
My local track just got new commercial grade office carpet and have been toldit has ok grip so far.
I ran yesterday on Astroturf and it was horrible. It was the worst the buggy has every been even though i was running the same tires as everyone else.
What are some things you would change if your buggy was lacking grip front and rear, almost a four wheel drift.
The first thing i did was take out the 6.1 D block and add 3deg rear toe, helped very little, and still had little steering.
I also should have taken out the direct drive and installed my slipper, didnt have enought time running two classes and no time between rounds.
Any helpful advice?
Thanks as always.
Any helpful advice?
Thanks as always.
#695
Any helpful advice?
Thanks as always.
Any helpful advice?
Thanks as always.
Have you tried the kit setup with largrr pistons and no anti roll bars, should drive nicrly on astro.
#696
If you can post your setup it might help people offer some advice, not all astro is high grip and running the 6.1d to give you zero rear toe is really only for very high grip carpet with cactus tyres that lock the rear in.
This is my current setup.
The first thing i did was to put the 6.4 D-block back on with 3deg of rear toe, i also unhooked the front sway bar.
#697
Loving this car on black carpet with Jconcepts tires!
We are currently using the kit setting on the rear link: center hole inside with 4mm under ballstud, 2mm under outer stud with 2mm spacers.
Saw a local fast guy is running 2mm under the inside stud (kit mount, not the +2 FT mount), with the outer mount reversed and 1mm of spacers (I believe this would make the link 3mm longer?)
What would those two changes do on the track?
#698
R/C Tech Elite Member
Everything is a compromise.
#699
#701
Right now i have the steel bulkhead at 25deg, what change would i feel if i put the 0 deg aluminum bulkhead on.
#702
If you have your steal bulkhead with 25' at front then you will only have 20' of total kickup, try turning it around to give you 25' kick up (confusing I know).
Others things to look at would be removing a rear inner camber link washer and moving you wishbones forward to lock the rear in more.
#703
I mixed myself up. deleted it. I was thinking about the 20deg block they had out also mixes things up even more.
#704
I understand the 6.4 +2 front axle is the same height as the 6.3 +3 height....is the difference in the new caster block or the new steering block?
I'm wanting to try the 6.4 caster with 6.3 steering block combo to make the front wider on carpet, and need to know how to achieve kit 6.4 +2 setting, thanks! (this worked well on the truck)
#705
