Team Associated B6.4 and B6.4d
#676
Kashima shock kits come with 23mm front shock shafts. You will either need to put 2mm internal limiters inside of the front shock bodies or buy 21mm shock shafts.
#677
Hi all, my kit came with 2 #8680 ball bearings that I can't find any instructions on where they should go.. did anyone else run into this? I've been through the manual 3x and cannot find any usages of those particular bearings. Thanks!
#678
These are the internal ball bearings to the ball differential.
#679
If you bought the carpet car with the gear diff, the two bearing left over are for the ball diff.
#680
Thanks!
#681
Tech Legend
why would you build kashima shocks without using the internals and shock ends you already have? Unless you plan on switching back and forth I dont see why you wouldnt rob those parts from the stock shocks..I know the chrome shafts are the "upgrade" but I prefer the TiN shafts, they seem to last longer.
#684
Does anyone have a setup they would be willing to share for 2CRC in Idaho for a B6.4 17.5? I see a number of posts here from people who live in the area and race there. I’m just getting back into it after about 25 years away.
#686
Does anyone race at Radio Control Hobbies and Raceway in CT? I've been out of the hobby for over 30 years and want to race stock 17.5 class. Looking for B6.4 tips, gearing, any help would be appreciated. Thanks
#688
I do. To my knowledge, the B6.4 with the kit setup (minus sway bars and a 7k 2 gear diff) is the way to go. I'll be getting one this week to replace my B6.2. For that track, schumacher mezzo rear tires and low profile cut staggers are the tires of choice. A Hobbywing justock esc is good enough for getting started and running for a while. 29 tooth pinion and 72 tooth spur is the standard there. If your just coming back, then most 17.5 motors will be good enough to get you into the groove. Radio Control Hobbies and Raceway (RCHR) has everything mentioned above and everything else for you to get up and running. They race 17.5 buggy on Wednesdays at 7PM and Saturdays at 5PM.
#689
Super Moderator
The steel bulkhead tends to give the car more front weight. I don't know if it helps traction rolling.
Anti-squat usually helps with on and off throttle. My experience, albeit on dirt, is that more anti-squat makes the car loose on throttle. Your experience may be different on carpet.
I think most people try and trim their tires or glue the sidewalls to prevent traction rolling, especially the front tires. Or they look for less aggressive tires. Another option would be to lower your ride height.
#690
As mentioned, the extra weight is about getting the front to grip and rear to rotate.
Good luck
