Team Associated B6.4 and B6.4d
#722
The silly things are the easiest to check. I'd start with batteries. Not just the car battery, but your transmitter. You can also check all the connections to make sure they are not loose and none of the wires are frayed.
#723
What oil weight are you running with the 2.5 pistons and 1.7 front 1.8 rear?
#724
I finished building a brand new b6.4 after upgrading from a b6.1 about a week ago. I gutted the b6.1 and transferred the same electronics over tot he b6.4. My first thoughts were the b6.4 definitely has a ton more corner speed than the older b6.1. However it definitely feels more chunky if that's the right way to describe. It felt heavier and more sluggish to accelerate. I guess it is intrinsically a heavier car with the 13mm shocks and the longer chassis. Is this consistent with what others have seen? Maybe I need a motor upgrade? I'm running the justock esc with the hobbywing G3R 17.5t motor tuned to pull ~6 amps. Mostly stock everywhere. Car weighed in at 1520 grams on the track scale. Racing on CRC black carpet as well.
#726
Has anyone on here tried using the Vision carbon chassis in their B6.4d? Thoughts on it would be appreciated - I typically run on clay.
#727
I never understood why people like using carbon chassis on a car that is already so close to minimum weight...the aluminum chassis puts weight low which helps to keep center of gravity low, a very important part of tuning the car. Not to mention how expensive the carbon chassis are...
#728
Sorry if this has been asked before. Going to picked up a B6.4, but wanted to know what spare parts i should have on hand? Obviously front arms, but some local guys are telling me front shock towers? If that’s the case should I go with aluminum? Also what would be the 3 or 4 must upgrades to have? Any help is appreciated.
#729
Tech Legend
From there I'd just have the usual suspension parts on hand, a-arms, hubs, steering blocks. Start with 1 or 2 of each and if you find you are breaking certain items more just pick up extras of that. Better to have it on hand that hope someone in the pits will or the hobbyshop if there is one has it on the wall.
#730
And the for 6.4 I'd highly suggest the aluminum front bulkhead.
#731
Minimum for me was alumn bulkhead, alumn steering and servo horn, ceramic bearings. Then better turnbuckles and Ti screws. Beyond that consider Ti drive slipper shaft, carbon servo brace, and FT hard carbon for any of those areas you break.
#732
Front arms would be the next most common and an aluminum bulkhead as the plastic ones break.
Upgrades: Initially the machined internal shock spacers and the bulkhead I mentioned above.
Buy an aluminum servo horn but don't put it on until you break the plastic one.
I'd run the plastic steering components for a while until you get better if you're new at this. They do absorb some impact.
3.5MM turnbuckles
That's it for club racing.
#733
GREAT info, thanks!
It sounds like the easiest solution for those (like me) who don't want to block up holes, drilling 2 additional 1.0 or 1.1 holes in the pistons may be the best bet. Would you recommend sticking with kit pistons (2x1.6F/2x1.7R) and then drilling 2x1.0 in the front and 2x1.1 in the rear? Would your recommendation change for carpet/astro/clay?
How are you blocking the holes when using the 3 hole pistons?
How long until AE comes out with blank 13mm pistons?
Does anyone have a good piston drilling set they recommend?
#734
