Team Associated B6.4 and B6.4d
#541
Anyone ever have issues with your aluminum servo horn having slop? The horn was a brand new Associated aluminum 25t I put on a Futaba servo. I put a drop of loctite like normal and tightened down the screw.
No matter what I do, it has slop, I can actually see the horn moving almost front to back but at an angle. So its not really front to back or side to side but at an angle when you turn the wheels by hand holding onto the tires.
I thought the horn was loose, not the case, the screw is tight but the horn almost fits too loose I guess.
It makes me crazy with this much slop in the steering, was debating trying a different servo to see it it is better with a Savox vs. the Futaba in it now.
Any ideas?
Thanks.
Any ideas?
Thanks.
#542
Any ideas?
Thanks.
Any ideas?
Thanks.
#543
I have noticed this enough times to start using only the pinch bolt style like ASC1370 rather than ASC1366. First, make sure the screw holding the horn to the servo is not too long allowing it to bottom-out in the servo threads before clamping the horn to the servo. Lastly, you can try pinching some Teflon tape or similar between the horn and the servo to take up play as an effort to use what you have.
Thanks for the pointers. I too see a pinch type servo horn in my future.
Thumbs up
#544
It kept them from traction rolling while others still were
#546
If it's not enforced use whatever you want I guess.
#547
Any ideas?
Thanks.
Any ideas?
Thanks.
#548
Got myself a bit confused. On the b6.4d kit set up is the laydown gearbox (91791) What is the other gearbox included with the kit? The stand-up (91788) or the layback (91790)? Will the gearbox not included in the kit fit the 6.4d?
#549
The dirt model used to come with the laydown and layback gearboxes, the layback moves the motor back for more rear weight.
#550
Got it. Thank you. I'm guessing the stand-up gearbox (91788) won't fit the b6.4d? Acociated's website doesn't list it as compatible.
#552
It should be compatible, someone just hasnt officially listed it. The .4 has the same holes in the back of the chassis as my .2s and the .3s so it should just bolt on.
Although it'll help, a layback transmission and the correct tires will be better than the standup transmission and the wrong tires. Maybe try the AKA impacts if its a loose type track, they can work REALLY well on those surfaces.
#553
I appreciate all the help, thank you. The track I am on seems to be either grove or super fluffy, like baseball field fluffy. The real problem is that I am not a good enough driver to stay out of that super fluff. Practice Practice Practice.
#554
How is steering affected when removing the 1mm washer from the steering rack that the ballstud connects to? I've seen setups with 0mm, 1mm (stock), and 2mm.
#555
By removing one or two washers allows the outside wheel to turn more in relation to the inside (less akerman effect). I tried this out last time on medium high grip carpet and it gives more steering. With the washer in the steering is smoother and I believe in lower grip (where its easy to overload the outsidecwheel) should generate more steering.
