Team Associated B6.1 & B6.1D thread
#2881
Has anyone tried the r1wurks laydown fan shroud system on their B6.1D with its layback transmission??
https://r1wurks.com/products/b6-1-laydown-fan-shroud
thanks
idbdoug
thanks
idbdoug
#2882
thanks
idbdoug
thanks
idbdoug
#2883
Associated must have found a box of b5m ball cups. Get some before they are gone for good https://www.ebay.com/i/254266999128?...&ul_noapp=true
#2884
#2885
I've found them to be stronger and slop doesn't develop as quickly; not to say the 6 series ones are weak. However, the B5 cups can contact the wheel with some low ride height setups as they are larger in diameter. I think they are good to have on hand if you have durability issues with the 6 series cups and they are also popular to install on other vehicles like the EB410.
#2887
Front tie rod gap for toe
I have been searching for the turnbuckle gap for the link to get 1or 2 or 3 degree of toe out for the front. Anyone know? I used to just eye it but i am sure there's a more precise way. Thanks a bunch. On Dustins Evans set up sheet 27.2mm is 0 degree.
#2888
There are too many variables to take into account for a fixed mm value, e.g. ride height, bumpsteer, spacers, tolerances. If you want to precisely adjust toe to a specific value, you'll probably have to buy an off-road set-up system by Hudy or Arrowmax.
Considering the amount of play and wheel flex, I think adjusting toe to approximate values is good enough for off-road cars.
#2889
I have used the kit setup on bumpy astro with anti roll bars and went down to v1 red front sprints and v1 white rears. I notice that a lot of astro setup do away with the anti roll bars and have the v2 red springs.
Am I missing something, but is my thinking that using the roll bar to control roll let's you use a lighter springs over a bumpy surface. I can get carpet when there are no bumps you can up the spring to control roll as there are no bumps to consider. I appear to be out of step, what am i missing?
#2890
Lightweight drivetrain with gear diff
This probably been asked, but I can't find anything about it... what would be the lightweight drivetrain components that can be used with the gear diff on turf? Is it just the bi-metal dogbones and the direct drive?
#2891
Has anybody priced up a complete 6.1 gearbox?? Just wondered the cost
#2892
Anyone have some set ups for the x factor motor on large clay track (OCRC). Looking for timing and hearing. Ran out of the box timing at 51 degrees and 72/27-28. Liked it but wondering if anyone as more experience with these motors as this was just with one day running the motor. Thanks in advance.
#2893
Who's running a Trinity X factor 17.5, what timing and gearing works well with this motor, on med/ large indoor clay med/high bite, thanks!
#2895
a lot. probably around 100 bucks to build a complete second gearbox. your best bet is to go on ebay and look for deals on parts. lots of guys buying kits and parting them out on ebay. prices are about half of what they are normally.
