Team Associated B6.1 & B6.1D thread
#2822
Richard adding a little more shock stroke will help. To me the only things that stick out on the setup sheet that will weaken the landing ability is the 27mm shock stroke, 28.5mm is a good starting point. The further you move the axles up the more it hampers the landing ability, so the shorter shock stroke and raised rear axle combined together will contribute to the bottom out issue. I'd start with just the shock package though as that is most important for jump handling.
Was this setup sheet made for your layout?
#2823
What were the air temps like at your track? Every 10 degrees or so, you should be going up or down 2.5wt on the oil to keep damping the same. There's a chart somewhere that shows viscosity vs temp that will help you nail oil changes when the weather fluctuates. Just a thought on why you are experiencing bouncy landings. Maybe your local temps are different enough to warrant an oil change.
#2824
Now that I've studied more setup sheets, it seems like most people are favoring the gull arms anyway. Out of 15 medium traction dirt setups, only 4 use flat arms and they are all with standup transmissions. Everybody else is on gull arms with standup or layback. I guess the best thing for me to do is just try them both and see for myself, but I'm curious. Anybody run flat arms with a layback?
#2825
21mm front, 28.5mm rear is the base setup and a pretty balanced starting point.
#2826
I think the setups you read may have as much to do with what the various kit configurations include as they do with set up choices.
#2827
Richard, one other thing to clarify is your shock rebound. Pop the spring off and put the spring cup back on the shaft. compress it and if it rebounds this could be causing inconsistencies. Try the stroke changes as mention previously but definitely check the rebound each race day as it will change because... physics.
#2828
I do, because I converted a B6D to 6.1D so I already had the flat arms. As near as I can tell, there isn't actually a difference in geometry between the two (tower positions cancel out arm location), so I don't consider the difference to be something to change for.
#2829
Question for you guys I have a factory lite i just got I want to run it on Astro turf track and carpet track. Someone told me the pucks and and ball diff are not good and I will tear them up. Is this right ? I got the gear diff and reg axles for it just in case . I also have a B6.1 D that I already setup for carpet from a buyer on the forum . I was gonna leave the factory lite setup for clay but I am pretty much gonna run at the track near me which is turf . Wanted to have a back up Buggy that’s why I got the 6.1D . Any help would be greatly appreciated.
#2830
#2831
clay / dirt = stock slipper / schelle nova slipper, any direct drive , aluminum pucks, stock driveshafts. ball diff
for me ... don't really care about pucks. I run stock driveshafts in all surfaces.
#2832
#2833
Beveled shock pistons?
Hey all, just joined and I’m getting back into racing after being gone for several long years. When would you use beveled shock pistons, and what advantage to they give you? Thanks I’m advance!
#2834
Depending on the direction of the bevel, shock decompression or compression is faster. The can be good on very smooth tracks, but I found set-up work much easier with normal flat pistons.
#2835
With a direct drive system, your ball diff will suffer for sure. If you are running 17.5 only and switch to a slipper, you may be able to get some decent runtime out of your ball diff and pucks, but a standard drive train is better suited to such (very) high-grip surfaces. Adding the Schelle Nova would be a good compromise , it is lighter than the AE slipper.
