VBC Lightning FX
#241
Regional Moderator
Most races here only allow Rubber, either Ride, or GQ tires.
I enjoy running with rubber since its more "realistic" but biggest factor is rubber last a lot longer than foam. Not a huge fan on constantly monitoring and adjusting the ride height and literally watch your money turn into foam dust and litter all over the track.
#243
Regional Moderator
From what I remember, they run the M in the front and SS or SSS in the rear. They use that as control tire for their club races. Ive ran on GQ tires as they first rolled out and it absolutely sucked. My car would not hook up at all. Ive since changed to Pit Shumizu and Ride tires and they both performed very well.
#245
1.5mm caster,
1mm camber,
Ride Yellow Big Bore spring on front,
Silver Side Spring from Team Saxo (VBC Side spring is softer, it could work)
5-5.5mm front height and between 6mm-7.5mm on the rear.
750 cst on the center damper and the same on the side damper.
All these with the Ride XR tyres.
I´ll try the new VBC this weekend.
#246
I just changed the main damper for the Flash-04 one. Now it doesn´t have that noisy play and works really smooth.
#247
Regional Moderator
short wheelbase
8.2 degree caster
5 degree active caster
1 degree camber
Most forward ackerman setting
Ride front soft spring
Stock yellow VBC yellow spring
700cst oil
8000cst damper tube oil
VBC hard side springs
around 5mm ride height front, 5.5 rear
I run on the old Ride tires, the newer Ride XR tires, and Pit Shumizu 573 front 572 rear
#249
Ceramic diff balls help. Also 1000-2000 grit wet sand paper makes them nice and smooth.
#251
You also want to stack the thrust washers to gain clamping force. Another option is to use the new Vbc Kawada spur that takes 18 diff balls.
When using thrust bearing install as so
Thruswasher)()nut
Both thrust washers and thrust bearing are availabe at www.gripworksrc.com
#253
The thrust bearing is installed instead of the 5x11 bearing. When you tighten the diff enough you will end up replacing the bearing a lot. Any board taps will also take out the stock bearing. I run mine with 3 washers no issues
#255
16, the diff is smoother and has more bite. So you don't have to tighten it down so hard. That being said. The new Kawada 94t spur takes 18 balls and works even better
