VBC Lightning FX
#136
I tested Serpent srpings @back. They feel a bit softer.Also, I already tested softer oïl in tube, but it was not better on feeling and it was slower on lap time. Cause in quick change direction, car is hard to drive.
I'll test harder front springs this weekend @ETS.
#137
Hello,
#138
Hello Guys,
I need some advices!
Im running the car with new Ride tires.
On corner exit, rear Wheel is always lifting.
Im using Ride soft springs in front,30k on both tubes and VBC soft springs for links.
Ill already harder front springs, harder links springs, but it's still the same...
Any idea?
Any idea?
50-100 k side tubes
#140
Hello Guys,
Any idea?
Any idea?
If so then its tweaked, not even weight on the rear tires.
Did the car diff out before the Ride tyres?
I would take a close look though and see if you can figure out why it's spinning out one way if it didn't before. Something has changed or moved, make sure front end is still level and square, nothing broke or binding. Check the rear pod to see its free on the pivot ball.
#141
Anyone test front damper tube?
#142
Front Low Downforce wing, rear high downforce wing..
when the traction is high, you may add more Caster
#143
For front damper, ask Ollie
Fred, both side are lifting. Never tested the car with another tires.Pod is free
#144
If anybody is looking to save a few $$ on a basically new kit...
http://www.rctech.net/forum/r-c-item...htning-fx.html
#147
Hi, I went to build the diff as part of my build yesterday and I cannot get the bearing to go on. The flanged bearing goes on fine but the normally one just does not fit. Has anyone else has this problem? I have ordered some other bearings to see if there is just a problem with the one I got in my kit.
#149
Is it possible to use a Tamiya F103 thrust bearing in place of the 3/8 x 1/4 bearing?
#150
Regional Moderator
The 3/8 x 1/4 bearing dont have any axial load, its more rotational as the drive side hub rotates. If anything, replace the 5x11mm with a thrust bearing as they wear out REALLY fast turning your diff gritty.
Try another 3/8 x 1/4 bearing and see if it fits, if not, you might need to carefully drill it out with a 3/8" bit
