Mugen MTX-3
Yes, Mugen makes a 16t pulley.
Just buy the stock pulley kit and the 16t is in there with the rest of em.
1st win!!!
just some updates on my mtx3 at the track, i ran 2mm offset in the rear and very little toe adj in the front, riding height was about 3mm, with the stock kit parts.. i need to get a setup board so i can give more acurate setting but it was dialed for the first time , i am a rookie and i took my first 1st place finish today!!!
Re: 1st win!!!
Did you try any of the things I sugested?
yes i set the front sway bar parallel to the ground the tightened it down, droped my ride heght, and adj my toe in the front and i was planted running 35s all the way around. also i ran a wider front end than i had ever ran and she was set. i took some tips from a pro driver and my toe was way too wide, this let me make the turns like day and night, couple more races and look out!!!
yeah its me craig the guy with the mtx3 white and orange, a few dozen cartwheels today, damn boards!!! sport class
O/K
I`m the guy with 1 arm and the pedal radio!
where u there today and what class r u in
Was`nt there today! Ask mike and the other locals ,Sean Taber they know me. I raced at the nats with Mike. I qualified 7th. in the A/main masters.
yeah im a new guy but this car is making it easy to learn! any other suggestions u have throw them my way, i have been learning from terance, and tommy chenault? close enough.
Sean is sponcered by Mugen, go to him at the track when you have a problem when you are racing there. Sean knows what to do at that track.Mention my name( Paul Rush )
yeah i talked to sean and borrowed his servo saver once, he is a cool guy, he wasnt there today. thanks alot i will be call u out when i get my hopup rear sway bar so i can set it up.
gear ratio?
i am running stock gearing in my mtx 3 which is 47/43 to 16/20 and i geuss these are 1.0 gears. i saw a guy at the track who had a bad a$$ motor but also had the 0.8 gears and it screamed!!
it seems as if my car goes though the gears a little slow for me, i race a technical track with at least one good long strecth, what are some suggestions for gearing. i asked the guy but of course i didnt remember it or right it down (in front of him )
Hi guys, i am debating if i should get another mtx-3 but not sure if i should hold on to my mtx-3 and wait for the mtx-4 to come out..does anyone has any idea when mugen will release the mtx-4 ? i am looking at maybe early next year any thoughts ?
