Like Tree1Likes
Xray T4'14
Old 11-22-2013, 04:29 AM
  #691
Originally Posted by jlfx car audio
Before topic goes back to hex s . I believe the wider settings r for higher traction situations if it tractionroles and if i cant remove any more toe i would widen my track width
So when you say adds stability do you mean grip. I know widening the front generally removes some front grip, is it the same with the rear?
Matt W is offline
Old 11-22-2013, 06:21 AM
  #692
jlfx car audio's Avatar
Trader Rating: 37 (100%+)
[QMatt W;12747713]So when you say adds stability do you mean grip. I know widening the front generally removes some front grip, is it the same with the rear?[/QUOTE]
I never said stability per say . i feel as they going wider removes traction and responsiveness and yes both ends of car I'm thinking has same effect
jlfx car audio is offline
Old 11-22-2013, 08:06 AM
  #693
Team EAM
Trader Rating: 79 (100%+)
Got a huge shipment of Hiro Seik T4 Screw kits in yesterday. Orange alumn top screws and titanium bottom. They are T4 kits but I believe almost every screw is there for the 14. I am going to check on that today for sure. I have extra's in packs of 4 as well as RC shims, wheel nuts and washers.
EA
EAMotorsports is offline
Old 11-22-2013, 08:16 AM
  #694
chasingthepack's Avatar
the rear of the 14 is very tail happy on the std settings ,the only way i could get the rear to stop stepping out was to go .5 wider on the fr + rr,it gives 3.25 of rear toe,and im going faster than with the 13 so i must be doing something right
chasingthepack is offline
Old 11-22-2013, 09:11 AM
  #695
cwoods34's Avatar
EA
Worth the money! Even after swapping every screw on the car I had plenty extra to use for weights, fan mount, etc..... So it's cheaper than buying small packs from other places. Plus it looks badass
cwoods34 is offline
Old 11-22-2013, 09:13 AM
  #696
b_recliner's Avatar
Trader Rating: 22 (100%+)
+1 awesome screw kit!
b_recliner is offline
Old 11-22-2013, 11:15 PM
  #697
Registered User
Trader Rating: 9 (80%+)
Hey Skiddins Were Did You Buy Those Torx Screws For The Bottom Of The Chassis Been Looking For A While But No Luck
Dan-Dan Team-X is offline
Old 11-23-2013, 03:21 AM
  #698
Skiddins's Avatar
Got mine from work, we got thousands in for a customer
The ideal place is a hardware shop that specialises in fasteners and fixings.
Skiddins
Skiddins is offline
Old 11-23-2013, 08:51 AM
  #699
For screw torx screws i would try eBay
Bony85 is offline
Old 11-23-2013, 12:54 PM
  #700
morgoth's Avatar
This is my current setup on CPX tires. The track is pretty tight and technical and I need a little more steering. The steering is close to what I want in the beginning of the run, but at the end the front tires overheat and I have to slow too much to make the car turn.
What could I do to get more steering? I'm thing of going to 2.5° rear toe instead of 3°, but that change looks a bit drastical to me. Isn't it? I think the car will be hard to drive after that change. Tomorrow is Q4 and Q5 so I can't practice a lot :-(
Link: http://cl.ly/SdgW
morgoth is offline
Old 11-23-2013, 02:15 PM
  #701
you forgot to post a link
Old 11-23-2013, 03:01 PM
  #702
chiefj48's Avatar
Hey All
Anyone have a problem mounting motor in chassis??
I'm using a kill shot motor and it hits the chassis.
chiefj48 is offline
Old 11-23-2013, 04:35 PM
  #703
5tylez's Avatar
does anyone know of the new T4'14 motor mount fit on the T4'13?
5tylez is offline
Old 11-23-2013, 05:06 PM
  #704
Warren Weaver's Avatar
Trader Rating: 49 (100%+)
Yes
Warren Weaver is offline
Old 11-23-2013, 05:14 PM
  #705
Trader Rating: 13 (100%+)
Originally Posted by chiefj48
Hey All
Hits the chassis, or top plate?
What gearing?
Sean B. is offline
