Like Tree1Likes
Xray T3 2012
Old 09-07-2012, 04:40 PM
  #3676
mikel33's Avatar
Trader Rating: 2 (75%+)
Originally Posted by syndr0me
That mount is a piece of s***. Save your money for the T3'13 where they got it right with two inner holes.
May I politely ask why it is a POS? I have had no issues whatsoever with mine.
mikel33 is offline
Old 09-07-2012, 04:45 PM
  #3677
syndr0me's Avatar
Trader Rating: 32 (100%+)
It pretty easily moves by several mm even when it's tight. The single hole for the inside mount isn't adequate, which is why you see the T3'13 prototypes and other companies going with two holes along the centerline for the mount.
I've gone back to using the inside mount and shoe goo which has been great.
syndr0me is offline
Old 09-07-2012, 04:47 PM
  #3678
Jon Williams's Avatar
^^This.
Jon Williams is offline
Old 09-09-2012, 07:10 PM
  #3679
haywood's Avatar
Trader Rating: 49 (100%+)
Default Spool vs. Gear Diff
Anyone running a gear diff in the front on carpet in blinkey 17.5? I'm guessing the spool is the most popular choice. If so what are you running in it?
haywood is offline
Old 09-09-2012, 07:26 PM
  #3680
mikel33's Avatar
600K. After a fair bit of back and forth, the spool works better for me. Others may feel differently.
mikel33 is offline
Old 09-09-2012, 07:29 PM
  #3681
Regional Moderator
CarbonJoe's Avatar
Traxxas 500K diff lube (easiest to find for me). You almost need to fill the diff completely, otherwise the diff action won't be consistent. Some guys use gray cleaning putty, while others use a foam earplug.
CarbonJoe is offline
Old 09-09-2012, 08:34 PM
  #3682
stro3579's Avatar
Trader Rating: 20 (100%+)
I didn't want to say that, that's why I said Shoe Goo it. I wish I never cut my tab.
stro3579 is offline
Old 09-09-2012, 08:35 PM
  #3683
stro3579's Avatar
I agree.
stro3579 is offline
Old 09-09-2012, 09:23 PM
  #3684
B00t13g's Avatar
Servo tape is working just fine for me and all of the abuse I dished out this weekend, the rest of the car didn't fair as well...
B00t13g is offline
Old 09-09-2012, 09:24 PM
  #3685
B00t13g's Avatar
On carpet a spool works better. I ran a gear diff up front with putty.
B00t13g is offline
Old 09-10-2012, 11:24 AM
  #3686
I would agree with this most of the time.
I was a big advocate of the gear diff in the front, the mechanics behind it just make so much more sense than a spool.
However, on most tracks a spool still is slightly quicker and slightly easier to drive.
I do find it is track specific though, if you need more initial steering on a very tight track, a gear diff will be quicker.
Bare in mind that i run either 13.5t or 10.5t boosted. In 17.5t blinky, a gear diff may give even more benefits.
Mb3195 is offline
Old 09-10-2012, 04:03 PM
  #3687
Originally Posted by FLAT OUT
Are they any shock pistons from other manufactures that fit the alloy shock body, Also has any one tried using different shock o rings for the bottom of the shocks. I just tried some much more shock o rings and they were to small and let air in.
Anyone ???
FLAT OUT is offline
Old 09-10-2012, 04:12 PM
  #3688
NolanP's Avatar
Anyone ???
Why if you don't mind me asking are you trying to change the piston's? I have heard of people adding holes or making them bigger etc. But most people just run the 3 hole piston.
Same concept are you refering to the price of said product or just cause you don't want to run Xray o-rings?
NolanP is offline
Old 09-10-2012, 04:25 PM
  #3689
The xray pistons come attached to a plastic frame, you have to use a sharp blade to remove them which generally leaves the edge of the piston a bit rough. this effects how the piston moves in the shock body. Im after a piston that comes loose and does not need to be removed from a plastic frame. I know alot of xray team drivers where I race change the o rings, personal choice I guess.
FLAT OUT is offline
Old 09-10-2012, 04:27 PM
  #3690
NolanP's Avatar
Most people I have known just use a little sand paper.
As for the o-rings I used the stock ones thats what Paul told me to use.
NolanP is offline
