Xray T3 2012
#3527
So with all of the discussion about how to set droop, I decided to build a video on the method I use. Don't be too critical, but I hope this helps and explains the method clearly.
+ YouTube Video | |
#3529
Maybe try this. Just theory, and not proven, but it sounds accurate in my head?
Back droop screws way off the chassis
Set RH to 5 mm measured at the center rear of chassis
Set chassis on RH gauge at a value of 5mm + ORH mm.
Tighten droop screws until axles begin to move
Use droop blocks and gauge to even droop out side to side(should be minimal)
#3530
This doesn't require taking wheels off or using any thing more than a stepped RH gauge and flat surface. Let me see if I can get this across...
1.First off this is assuming properly functioning mechanics with a flat chassis. It will not be reliable if the shocks are not smooth, or there is a significant tweak.
2.Complete the following with the rear of the car facing you and near to the edge of your pit board closest to you.
3.Back droop screws away from chassis to ensure they are not effecting RH
4.Set RH to desired amount (5 mm lets say)
5.Slide stepped RH gauge under right rear corner of chassis so that chassis sits at RH + ORH value. (5 mm + 2 mm for this exercise)
6.Position car and gauge so car is on the pit board, but the thick 1/3 of the stepped RH gauge is hanging off the board (gauge is parallel with belts)
7.While watching the right rear shock shaft, just below the bottom of the shock body, gently lift up on the back edge of the RH gauge 1-2 mm. (Chassis will lift)
8. If the shock shaft stayed in the same position relative to the shock body and did not extend out any, you need to add droop.
9.If the shock shaft extended out at all you need to take away droop.
10.Repeat steps 7-9 until you are right at the point where the shaft just moves, but almost imperceptibly.(I had a light on the shaft and was down at eye level with the shock body/shaft junction)
11.Repeat this procedure with the gauge on the other edge of the chassis and looking at the left rear shock.
Someone else try this and see if you think this works? I don't always trust myself this late at night.
#3531
One thing I'm shocked about is your ride height setting at 5m. Does your car pass checks at races? I usually say 5.5m is my lowest (unless its a asphalt race where rh isn't checked)..
#3535
Hey everyone i need some setup help,
Im under steering on this particular corner, and feel like im lacking abit of corner speed throughout the whole track
on this track layout,
my current set up is here http://forum.teamxray.com/xform/inde...&setup=t3_2012
Thanks.
Thanks.
#3536
where is your understeer entry? or exit? I am sure you have already tried it but how about adjusting the front rollcenter. If you are pushing on exit I would go down from 1.0 to .5 on my front tow out setting. otherwise play with spring and oil.
#3537
Those are the simplest things to try.
Skiddins
#3538
Drop the front roll center at the hinge pins and drop both diffs.
If u sill need more, drop to 1.2 front sway bar and remove ackermann shim from steering rack.
#3539
Thanks.
Thanks.
This solved the problem for me.
#3540
Has anyone actually measured the values of the new progressive 2.2-2.6 rear springs?
I have a pair and they seemed ok for my first use (more testing required) but can't see how they are progressive as the coils all look the same etc.
Skiddins
Skiddins
