Team Associated TC6 Thread
#3661
If you look at the chassis, there isn't much space to fit a double steering post set up, this is something we are discussing on another thread at present (Reflex)
#3662
The single bell crank is what the TC6 engineer feels is best. I don't know if one works better than the other because I have never had a car that gives both options (for back to back testing) but the single system works pretty well on the TC6.
#3664
Thanks for your respond!
G
#3665
hi little john i checked them all good mate but i did find the problem rear diff to tight
#3667
hi
can someone help me does thetc5 springs fit tc6 shockers and what do u guys mean when they say 1-1.1.5 shock piston. and can u tell me what is the ballstud sliver and black whats the differences thanks guys
#3668
The pistons you mention have 2 1mm holes and a 1.5mm hole, they do not come with the kit but can be bought from Reflex Racing (http://www.reflexracing.net/proddetail.asp?prod=RSD006).
Black ballstuds have a short 'neck' whereas the silver ones have a slightly longer 'neck' under the ball, I think it is 0.75mm longer, which basically is like having a 0.75mm shim underneath a black ballstud.
Regards
Neal
#3669
hi
thanks neal for the info mate to good but one thing where would i get the sliver ballstuds from thanks
#3670
You can get the silver 'long" ballstuds from amain and probably others. I know amain has them listed under tc5's. I would recommend getting the 10mm thread length if you are planning on using them for the front outer ball. I had the 8mm loosen using a 2mm ballstud washer and then it would not tighten again because the few threads it was using became stripped.
#3671
The Tc5 Springs are the same as the Tc6 springs, which have actually been the same since the TC3 I think.
Regards
Neal
Regards
Neal
These are an AE part so any hobby shop that sells AE should have them or can get them/
#3672
AE Blank 1/10 Pistons, #6463. They are made from a material that is easy to drill.
AE Silver ballstuds,#31285 10mm length, #31293 10mm Ti Ni
#3675
hi
