Team Associated TC6 Thread >
Like Tree20Likes
Old 09-16-2011, 09:47 AM
  #3811
Originally Posted by Big Features
A ball diff will add a lot of steering and free up the car when the bite really comes up. Folks that run Mod like it becuase it not only adds steering, but is less maintenance between runs. It really has its pros and cons.
For me, I race stock. You just cant beat a buttery-smooth ball diff. The ball diffs are a bit lighter too, less rotational mass.
Mike
Did you mean gear diff in the first paragraph?
JamesL_71 is offline
Old 09-16-2011, 10:59 AM
  #3812
Gear diffs blow the web gears too much at high rpm, whereas a ball diff could be spun alot faster with no signs of failing, specially if you use ceramic balls , and goop the diff bolt well !
bertrandsv87 is offline
Old 09-16-2011, 12:12 PM
  #3813
Odin544's Avatar
Trader Rating: 93 (100%+)
Originally Posted by Rick Hohwart
This one is Keven Hebert 17.5 from Cleveland last year:
http://www.teamassociated.com/pdf/ca...hamps_2010.PDF
The Steve Weiss WCRC Club race setup should be pretty good on carpet too. I'll start with my WCRC Club race setup at the IIC carpet race. It should be pretty good.
Im sorry if this is a silly questions as I'm new to TC. But 3 degrees positive toe in the rear? Would this help the car turn as the inside rear wheel would be lighter than the outside, and with the positive toe it would help it turn better?
Odin544 is offline
Old 09-16-2011, 01:34 PM
  #3814
Suspended
Thank you very much for those. I will try them Sunday and go from there.
tutankhamen is offline
Old 09-16-2011, 02:05 PM
  #3815
Rick Hohwart's Avatar
This refers to 3 deg toe in. This stabilizes the car and improves rear traction.
Rick Hohwart is offline
Old 09-16-2011, 04:07 PM
  #3816
cwoods34's Avatar
The aluminum screws are very nice. I didn't have any problems tightening them enough to use on the bottom of the chassis for the bulkheads. The blue looks sick against the black RSD camber mounts --- I'm highly considering getting the whole car done in black now
cwoods34 is offline
Old 09-16-2011, 04:36 PM
  #3817
Big Features's Avatar
Yes, good catch my friend. I really should think about posting following a few "cocktails".
Big Features is offline
Old 09-16-2011, 04:38 PM
  #3818
Originally Posted by Asharus
Thanks for the answer, but did you mean gear diff in your first paragraph?
Yes, good catch. I should really think about posting following a few "cocktails".
Old 09-17-2011, 01:44 PM
  #3819
way too many cocktails...if you post twice!
olly986 is offline
Old 09-18-2011, 06:53 AM
  #3820
Same question, different ask'rs
Old 09-18-2011, 08:51 AM
  #3821
How quickly are yall going thru the 6x10mm bearings in the front hubs? After 2 weeks, I have substantial play in left front bearings, mild play in the right front, mild play in the left rear.
Im just getting back into TC racing, so Im a little rusty. But I wasnt tagging walls broadside, just a couple front taps on the bumper.
Is this a known problem area? Are there more durable bearings available(like the Acer Ceramics)?
Old 09-18-2011, 09:15 AM
  #3822
swimbikerun's Avatar
Trader Rating: 108 (99%+)
Is it the bearing itself or in the steering & rear hubs? If you score the inside of the hubs with a hobby knife it helps take away some of the play.
swimbikerun is offline
Old 09-18-2011, 09:32 AM
  #3823
ghiro's Avatar
Same story here , but in my car it happened after 5 months of racing. I've replaced the stock ones with ABEC35 bearings.Cheaper tha Many others but perfect for the purpose and better than stock ones.
ghiro is offline
Old 09-18-2011, 12:48 PM
  #3824
Originally Posted by swimbikerun
Is it the bearing itself or in the steering & rear hubs? If you score the inside of the hubs with a hobby knife it helps take away some of the play in the hubs.
Well Im not 100% sure actually... I will have to check that out.
Old 09-18-2011, 01:03 PM
  #3825
wtcc's Avatar
The bearings in the steering and rear hubs are not good. They hardly survive easy crashes. I immediatly replaced them with ceramic bearings from Acer and never had a problem since them (since 10 months).
wtcc is offline
